Motorhome awning for caravan
Aug 26, 2020
12
15
Hi, I am in the process of buying a Kampa Dometic Rally air pro 260 for the caravan, the dealer says he has none left in stock but does have the 260s motor rally air pro which will fit. He just needs to throw in a draught skirt and it will be fine. Says it has the dual bead for the motorhome (4mm and 6mm) but apart from that identical. I am a bit apprehensive without seeing it as this is a replacement to an "ex display" I got delivered from said dealer which looked like it had been used for about 4 seasons.
Thanks in advance, Scott.
1,865
6,935
I can’t answer specifically, but a quick Google shows loads for sale on line with massive price differentials. £400 up to £906.25.
12
15
Thanks John, I’ve managed to get it sorted now and got one ordered. I also emailed Kampa direct and got the reply although doesn’t matter now as I got the caravan model
“Thank you for your enquiry.
The fitting heights for ‘S’ are 235-250cm, this is the same as the caravan awnings.
Therefore it will be compatible“
Reactions: Jcloughie
