- Jun 20, 2005
- 20,223
- 5,434
- 50,935
Most drivers don’t know how to open the bonnet🤪A driver should always know how to deactivate cruise control. If you don't you shouldn't be using it.
ATC is one of the best things since sliced bread!
I think this needs a little more clarification,Every outfit has a certain threshold speed above which it will not recover from a snake without active intervention of some sort. If a snake does occur, it will recover of its own accord when the speed drops below that threshold.
The closest that I've come to a bad snake when towing was last year travelling down the M5 southbound just past Gloucester.
The motorway was quiet, the road conditions were good and the car and caravan were correctly loaded.
I was passing a 7.5 tonne panel van in the middle lane at about 58mph, not a problem, but on this occasion a large Bentley saloon car came past in the third lane at what must have been at least 100mph.
Fortunately for us, I'd seen him blasting toward us and instinctively eased off just in time as he passed us, creating a massive bow wave of disturbed air which, coupled with that from the 7.5 tonner panel van, induced some quite severe instability in our unit.
I took my feet off everything to let the speed bleed off, and the panel van driver was alert to the situation and also backed off to give me some room.
Thankfully the bad wobble didn't develop into a full blown snake, but it was the most buttock clenching moment that I've had when towing.
I concur with the Prof, the instability threshold can change, sometimes quite dramatically when a speeding vehicle creates such a massive disturbance of air and slipstream.
If I hadn't seen the idiot high speed Bentley driver coming things could have been much worse.
Cruishally the threshold is not fixed value, in fact it is constantly changing becasue it's highly reliant on the driving and road conditions.
Elements such as a side wind or bow wave from a passing vehicle, it could be a change of direction or change of road surface, for example tram lines or a wet patch, any one or combination of these will lower the threshold.
But even more than the variability of the threshold point, it's actually two thresholds, and upper one that needs to be exceeded to initiate instability, and to bring the outfit under control the speed must brought down below the lower threshold point. The band between the threshold's is a range of speeds at which you or might not experience instability, but if you have instability you must bring your speed down below the lower threshold.
I cannot condone the concept of trying to accelerate out of a loss of control, as by increasing your speed you are adding kinetic energy to the outfit which can be converted in to a more severe instability action.
Under the conditions I've bold underlined, any outfit should be stable regardless of how badly matched or how badly loaded - and such a speed cannot be used as a safe speed to tow at as conditions are often far from perfect.It is true that the threshold speed will vary depending on prevailing conditions, but to allow comparison between different outfit configurations it is usually determined under ideal conditions such as a straight and level open road and calm weather conditions.
One should not confuse the threshold speed above which the outfit will not regain control of a snake without any active intervention and the speed at which a snake is induced in the first place. That speed can be significantly lower.
It is the responsibility of every driver to ensure their vehicle is safe and not likely to lose control under driving conditions without having to rely on non obligatory systems like friction couplings, or friction dampers, or ATC or similar systems.... ATC is one of the best things since sliced bread!
There are so many factors that affect the behaviour of an outfit. Single or twin axle is just one. Most important is the polar moment of inertia of the caravan, but also the lateral compliance of the towcar’s rear suspension. One could go on and on with further criteria.Many factors are mentioned above except that a twin axle will behave differently to a single axle firstly the twin getting into a situation where a snake will occur and secondly the driver resolving the snaking while towing the twin axle.
These are issues of significant interest and critical examination in German caravan test, but do not even warrant a mention in a British 'Aren't the curtains nice' tests. They don't even measure the actual loads on the individual wheels of a caravan!
I only categorised ATC etc as non essential becasue presently under UK law they are not required to be fitted "as standard" , and even if they it is fitted its not required to be used, and it can either accidentally or intentionally not set up. Its legal in the UK to have them fitted but not engaged hence not essential.An interesting take Prof. I never thought about a third tier non essential aid.
I never had ABS on my earlier cars. I was taught Cadence braking and even double de clutching.
Looking back an anti snaking device was at the top of the CC list of most wanted accessories. Not mandatory , maybe just a placebo?
But we were taught the skills that precluded the need for such devices.
So yes , I agree they were third tier as not supplied with the caravan, being considered non essential.
Ironically today ATC , anti snake devices have become standard fits . I wonder if anyone would buy a new car or caravan without these systems?
ATC is not a panacea for a badly arranged rig.
Country lanes coming this Friday! But the ones I know quite well so that will be helpful. I will probably make some people miserable as some of those roads are narrow and have raised, concrete edge - so I suspect I will hit high 20-ties on the speedometerThats good news and obviously your pleased, nice weather, next thing for you will be country lanes or bad weather.
Glad it all went well for you.
Glad it went well. One trick to make Milenco mirrors easier to adjust is to disassemble the ball joint and if there is a injection moulding line slightly above the ball surface just very gently smooth it down with fine emery.Country lanes comming this Friday! But the ones I know quite well so that will be helpful. I will probably make some people miserable as some of those roads are narrow and have raised, concreate edge - so I suspect I will hit high 20-ties on speedometer
I also bought bigger mirrors as the one I got with caravan (Milenco Aero) were bit hard to adjust and narrow. Now have XXL ones!
Crikey someone with a car giving worse mpg than mine! Glad it went well.Little update after next 600 miles. Caravan still in one piece.
Regarding country lanes, its 1:0 for them. I had to take very narrow turn. Now I have new side light!
Besides, I found driving with a caravan rather relaxing. Drove from Essex to South Wales, and except that I have to fill the tank in my thirsty CRV (18 mpg), otherwise I wouldn't make it, it was nice and slow - driving around 52-55 miles per hour. Everyone was overtaking me so I didn't need to pay so much attention on what is in front of me.
New, huge mirrors made a lot of difference, with previous one I had hard time to judge if I can change the lane, now its much, much easier.
