New battery technology
8,981
We did the same in a Renault 10 (Rear engined ) car, and its amazing that as little as 25Kg bag of stone chips can make such a difference to the handling of a car. worth bearing that in mind when hanging 75 to 100kg of trailer nose load onto a car!
This one also required some ballast in the front boot. Princeton mast in the far distance.
5,200
FWD on gravel roads was very scary. At least with RWD you could still control the car. The worst RWD car even built was the Corvair which was dangerous from day one!
A few friends had the R8 and the R10 and as you say they used to carry a bag of cement under the front hood to give the car some stability on the road. We did not have motorways in those days and dual carriageway was almost unheard of at the time.
This is a picture of the main road that interconnected our cities in the sixties.
Sam Vimes
2,526
2,028
12,935
My Triumph Herald had the unsual transverse leaf spring at the rear to assistt the independent suspension. The strange camber angle on the rear wheels was very noticeable. Many people used to put additional weight in the boot to straighten the angle up and improved road holding in the winter. A paving stone seemed to be one but I just kept all my tools in the boot.
Did have a half shaft break once which resulted in a horizontal whee l :-(
5,200
I once drove the Herald on a test drive that had a supercharger fitted. I turned right at the traffic lights and floored it a bit and nearly spun it around. Took it straight back to the yard as got one hell of a fright and I was only 18 at the time when you are supposed to be fearless.
3,491
Even with ballast in the front boot, the Imps could be tricky in winter conditions - I got caught out in heavy snow in North Wales in the winter of 78/79 - lost the back-end and slid into what I thought was a nice soft hedge but turned out to be an ivy-clad stone wall, very solid!
Having had a part-time 4wd, Hyundai Santa Fe, where the momentary delay was noticeable with front wheels scrabbling for grip until the rear drive engaged and then switched to full-time 4wd with torsen centre differential, VW Touareg, which varied power between front and rear according to grip - I wouldn't want anything less in future.
8,981
My Jeep could be a handful in snow/ice as you were not allowed snow chains or studded tyres in Ontario on tarmac roads. It could easily pirouette if given too much welly.
May 30, 2024
101
116
635
As an enthusiastic 18 year old, the rear panels of my Imp took a bit of a beating. Never hit anything with the front though.
8,981
As a matter of interest does anyone know what tyres British police or emergency response cars fit summer/winter?
3,491
Google AI gives - "British emergency service fleets, particularly the police and ambulance services, predominantly use all-season Michelin CrossClimate tyres due to their excellent performance across a range of temperatures and conditions, including light snow, eliminating the need for dedicated winter tyre changes"
8,981
Just like I have been doing for some 10+ years now, but not with Michelin as their aquaplaning on curved surfaces wasn't the best. although they were fired to our 2007 Note at one time!! So I now use Goodyear Vector All season Gen 3. But it all depends on what your criteria are for aspects of tyre performance. . Wonder how much Michelin paid Google for that search result?
