Interesting to watch & hear how long they do the gas testing for and another product with bonded side too ( in his words stops the caravans leaking ).... and three inspector's to check things....
Sproket said:Interesting to watch & hear how long they do the gas testing for and another product with bonded side too ( in his words stops the caravans leaking ).... and three inspector's to check things....
foggydave said:...................In my experience on any linear production line the 'Snag' system in some form or other is used. ................... To do this the trouble shooter knows every minute aspect of production.
I do wonder how far on a low production run quantities a company could realistically automate the build process to obviate the manual input, ............................
As for the method of construction I am just glad that the weakest componant in longevity ie timber has been excluded.
All consumer products tend to evolve in small increments so as not to scare the public with too radical a change. ........................
Rodone said:Hello all,
Hearing the stories about the water ingress problems with new vans, brings to mind a very unusual van that I came accross on a CL in Somerset around 15 years ago. I have to admit it was not a very good looking van but, because of its unusual looks I asked the owner about its history etc So far as I can recall his van was pre production and had been made ( I think) on the Isle of Wight by a boat building firm. It was made from GRP or similiar, and I suppose, could best be described as a boat upside down with wheels , apart from the windows , door etc, it was one piece of moulding and the owner was completely dismissive about water ingress - he had no experience of it nor any fear that it could happen in the future. I wish that I had made a note of its origins but did not. Never saw another one, but often wonder if perhaps the caravan producers of today could use some fresh thinking from outside the (tin) box, and if so,builders of boats may be useful sources of knowledge when the main object is to keep water on the outside of the structure.
"foggydave said:Romini Isle of Wight
http://www.google.co.uk/url?sa=t&rct=j&q=&esrc"s&source=web&cd=3&ved=0CEYQFjAC&url=http%3A%2F%2Fwww.smallmotorhome.co.uk%2FResources%2Fromini4pgebw.pdf&ei=BtrPVJK-JM7Uao-ZgsgM&usg=AFQjCNFdWx0tLPvw4hnanGOOJhiE36eq5w&bvm=bv.85076809,d.d2s&cad=rja
Raywood said:I am afraid the small scale production of firms like Coachman does mean that applying the sealant has to be done by hand as robots would simply be too expensive for a firm that size. Possibly some work could be done to improve the technique though which could work out cheaper if it reduced the number of damp claims.
Foggydave seems to have summed up most of the problems admirably though.
foggydave said:Hi Prof
I agree that water ingress is the problem but I think the biggest danger of water ingress is the effect it has on the frame ie the wood. If the wood used in carvans was fully pressure treated or even better a good quality hard used then the effects of water ingress would be mitigated as any weakening of the frame adversly effects the integrity of the stabilty of the body of the van. One of the advantages of using wood in the frame of a building is that the building does not travel down the motorway at 60mph or is pulled over rutted fields so flexing the building.
A universal law of selling is that if you have finite customers the product must have a finite life span. As long as that period is felt equitable by the consumer for the cost of the product then this is acceptable.
Your final paragraph I think is the nub of the problem. Cost! The cost of tooling and restructuring. which must be passed onto the consumer in the short term to claw back the investment. It would be a brave manufacturer who's product cost three times as much as an eqiuvalent brand simply because he can say my product lasts twice as long and will have a slightly higher resale value than the other brands. Also bear in mind this new product will have no tangible differences. The driver behind real change has been government legislaation bringing in raised standards mainly for safety. Unless there is a universal change at the same time by all manufactures in caravan construction then you cannot expect one manufacture to commit his company's future to such an endeavour. So it must be gently, gently as money for change allows
