A good move as we use a Milenco one to measure our nose weight which is 140kg and find that it is fairly accurate. As for taking it back to get your money back surely that has to be a joke or a TIC comment?Pillbory said:Thankyou Prof. I bought a nose scale today (a calibrated one) so plan to make sure I have a good balance all round once I get my head round the figures. I have two 5 year olds that will be in the car, and that is my first and ultimate concern, so safety first.
Buckman said:A good move as we use a Milenco one to measure our nose weight which is 140kg and find that it is fairly accurate. As for taking it back to get your money back surely that has to be a joke or a TIC comment?Pillbory said:Thankyou Prof. I bought a nose scale today (a calibrated one) so plan to make sure I have a good balance all round once I get my head round the figures. I have two 5 year olds that will be in the car, and that is my first and ultimate concern, so safety first.
ProfJohnL said:Buckman said:A good move as we use a Milenco one to measure our nose weight which is 140kg and find that it is fairly accurate. As for taking it back to get your money back surely that has to be a joke or a TIC comment?Pillbory said:Thankyou Prof. I bought a nose scale today (a calibrated one) so plan to make sure I have a good balance all round once I get my head round the figures. I have two 5 year olds that will be in the car, and that is my first and ultimate concern, so safety first.
Deadly serious.
Buckman said:ProfJohnL said:Buckman said:A good move as we use a Milenco one to measure our nose weight which is 140kg and find that it is fairly accurate. As for taking it back to get your money back surely that has to be a joke or a TIC comment?Pillbory said:Thankyou Prof. I bought a nose scale today (a calibrated one) so plan to make sure I have a good balance all round once I get my head round the figures. I have two 5 year olds that will be in the car, and that is my first and ultimate concern, so safety first.
Deadly serious.
Why would you be deadly serious as our Milenco calibrated gauge is fairly accurate or are you just scaremongering? Rather use that than nothing at all and rely on guess work. If they were so bad why do the clubs recommend using them?
otherclive said:Buckman said:ProfJohnL said:Buckman said:A good move as we use a Milenco one to measure our nose weight which is 140kg and find that it is fairly accurate. As for taking it back to get your money back surely that has to be a joke or a TIC comment?Pillbory said:Thankyou Prof. I bought a nose scale today (a calibrated one) so plan to make sure I have a good balance all round once I get my head round the figures. I have two 5 year olds that will be in the car, and that is my first and ultimate concern, so safety first.
Deadly serious.
I think Prof is questioning the 140kg which seems high for a caravans A frame hitch load, when most are 100kg maximum.
Buckman said:otherclive said:Buckman said:ProfJohnL said:Buckman said:A good move as we use a Milenco one to measure our nose weight which is 140kg and find that it is fairly accurate. As for taking it back to get your money back surely that has to be a joke or a TIC comment?Pillbory said:Thankyou Prof. I bought a nose scale today (a calibrated one) so plan to make sure I have a good balance all round once I get my head round the figures. I have two 5 year olds that will be in the car, and that is my first and ultimate concern, so safety first.
Deadly serious.
Our nose weight is actually quoted at 150kg so we are 10kg under it. No issue towing with that nose weight. It is an ALKO stabiliser.
Buckman said:Why would you be deadly serious as our Milenco calibrated gauge is fairly accurate or are you just scaremongering? Rather use that than nothing at all and rely on guess work. If they were so bad why do the clubs recommend using them?
ProfJohnL said:Buckman said:Why would you be deadly serious as our Milenco calibrated gauge is fairly accurate or are you just scaremongering? Rather use that than nothing at all and rely on guess work. If they were so bad why do the clubs recommend using them?
The fundamental method measurement of nose load requires the hitch to be at the same height as when it is coupled to the tow vehicle. Any measurement system that fails to observe that fundamental requirement does not measure the nose load.
Using a spring loaded nose weight gauge is better than nothing but it is not the correct way to measure. and the degree of error cannot be determined. The so called calibration of one manufacturers nose gauge only confirms that when it is loaded with a particular load it will give a consistent reading, it does not guarantee any convergence with the height of the tow hitch. This is particularly important with twin axle caravans where the rate of change of nose load with hitch height is very large.
You will get just as good if not better results from using bathroom scales and teh method I have given - without the cost of buying a piece of kit which actually does not do the job it is sold to do.
I am not aware of the clubs endorsing any particular make of gauge. If they are Then you should ask them to justify their endorsement.
Our Milenco starts out a lot higher and goes up to 400kg Milencootherclive said:Looking at the Milenco website is says the gauge is good for 130kg only.
DaveA1 said:I've got a Milenco guage, travels in the front locker. If it's wthing 10kg thats fine.
otherclive said:I think Prof is questioning the 140kg which seems high for a caravans A frame hitch load, when most are 100kg maximum.
EH52ARH said:But Prof, the Unit in the picture is Serialised and has a recalibration date of 2025, so at least 7 year between calibrations , that's a very long time. Maybe it has a screwable rod at the top to ygive a variable length.
I will stick to my old way of bathroom scales and up or down by 2 inches on my tow hitch makes about 1 kg difference on my scales, with the length of our caravan and keeping the C of G low in the van.
And I only got the scales as The wife says they weigh , 10 kg heavy. 😛
