Newbie electrics
Jul 8, 2020
Do I have to have the van on"car" when towing
Do I have to disconnect the battery when I arrive on site and use ehh
Sorry to be such a dumb dumb but we are really new to this
2,883
Welcome to the forum, you would not normally have to disconnect the caravan battery when towing,
But which caravan do you have make year and model. As there are a lot of differences.
6,263
When towing I press the switch on the 12 v section of the power supply unit which then allows battery charging and fridge cooling. On arrival the battery isn’t touched at all when you connect to site 240v EHU.
Jul 8, 2020
Thank so much for your reply.
The caravan is a 2003 coachman pastiche 420/20. We have been away these last three days just to see what we have so didn't go too far, luckily.
All ok in van, hooked up, made a cup of coffee and then everything started to deteriorate inside caravan,even electrics not working (3 pin plugs).
Been advised battery needs attention and get battery charger checked. Looking for someone to look at charger for us and battery going to garage to check and charge.
936
I do not know why you have been advised to do anything with the battery if the problem is with the 3Pin Mains sockets.
The two have nothing to do with each other.
If you have just bought the van, do you know when it was serviced last?
If that is unknown then I strongly advise getting it serviced by an Approved Workshop mobile engineer who will be more than happy to show you how everything works safely.
You will find a local engineer here: https://www.approvedworkshops.co.uk/
Jul 8, 2020
It was serviced March 2019 and has been well looked after. Just plugged duh in didn't know about looking for amps. We will consider service so that we can see what's what. Thanks for your advice.
Jul 8, 2020
Electric kettle and We just switched on socket only for microwave.
In our ignorance we thought plugging in to ehu would charge battery and That was it.
936
Depending on what wattage your kettle is , if a normal domestic 3Kw type then that draws 13 Amps and the microwave will draw at least twice its rated power initially on start, so a 800w unit will draw at least 1600w, or almost 7 Amps.
The van is limited to a max of 16Amps but you were probably drawing 20Amps, so tripped the MCB or the site supply bollard trip (most likely the site bollard as that is the one that normally trips before the van.)
What should happen when hooked up to mains and the battery charger is switched on, it should keep the battery charged, but that itself is drawing power as is anything else using mains power such as water heater, fire etc
Also, not all sites have 16Amp hookups, some are limited to 10Amps so you need to ask when arriving on site and work out what you can have on at any one time.
Moderator Note: I put RCD instead of MCB which has now been rectified.
Thanks to Bertiboy for pointing out my faux-pas.
Thanks Damian I can't believe we are so stupid. Still this forum is so useful. We are ok with everything except the elctric side of things.
2,399
Hi and welcome to the forum.
We all have to learn, so don't be afraid to ask if you're not sure of something.
If you're on site and something unusual happens there's this forum, or ask a nearby caravan owner.
Most will be happy to help a new owner.
Oct 3, 2013
890
90
18,935
The van is limited to a max of 16Amps but you were probably drawing 20Amps, so tripped the RCD or the site supply bollard trip (most likely the site bollard as that is the one that normally trips before the van.)
Damien,
An RCD circuit breaker does not operate for an overcurrent,only an earth fault.
2,069
i would get a Low wattage Kettle / Toaster & Microwave low wattage (Daewoo) we find this is better suited for a touring caravan ..
2,883
I disagree, we have done the 20 minutes kettle, the just browned toast, whilst the eggs were overcooked on the gas, we now use a reasonable kettle 1800 watt. normal toaster , as the gas cooker fails on toast.
The microwave works fine, even on 10 amps, just do not use them all at the same time. Remember the water heater is powering up for 20 minutes after a shower.
2,399
We have a low wattage kettle, a normal domestic electric toaster and microwave.
It's all in the timing. πŸ˜‰
For the occasional off grid trip we have an old school whistling kettle which we normally keep at the back of the pot and pan cupboard.
2,069
Some Prefer there own choices (Parksy) but we brought a Sunncamp low watt cordless kettle i filled it to 2 cups it took 5mins to boil . the Toaster 730w - 870w
(We never use the gas cooker in our caravan)
i even make my scrambled egg in the microwave .
Take Care Keep Safe
936
Damien,
Yes My Bad !!! was thinking about another issue at the time and put an RCD instead of MCB.
I will flog myself and read some more of LOTR as pennance !!
2,883
You must have a "Whisteling " kettle even if you never use it. πŸ˜€
Reactions: Parksy
2,399
That whistle for the first cup of tea of the day is one of the nicest sounds associated with caravanning.
It's nicer still for Herself because hers is served to her in bed.
