Hi all,
I'm about to pick up my first caravan and having never towed before, I've got a few questions...
The caravan I've bought (Bailey Pageant Series 6) apparently only has one electrical cable - this is good as my towcar only has one socket - is this normal? (for the caravan, not the car). Would the cable on the caravan be a standard 7-pin? (that's what the female socket on my towcar is). If so, would this also handle the split charging for the caravan's battery etc? If not, would it be a european 13 pin jobbie (technical term) and would I need an adapter? Or do I need to change the towing electrics on my towcar to provide the extra socket?
The caravan also has an alko hitch lock (I think with stabiliser), I have a swan neck towball - will this be OK? I have read that I need a grease free towball for the stabiliser - can someone confirm this?
From my reading so far, I know I'm going to need a number plate and towing mirrors but is there anything else I need to have/prepare for in order to ensure I can tow the caravan home? It's a private purchase and the shops will be shut when I pick it up so I know I need to be prepared but being new to all this, I'm not sure on everything I need to do.
