Night heating in winter - Fanmaster mk1 or ??
8,358
Call me “Ye of little faith”,!
We never sleep with any gas appliance on. We have all the smoke and CO alarms but you just don’t know what may fail.
Winter tog duvets work very well.
We would also never use gas heating on the rare occasions when we did put heat on overnight. But had no problem using gas during day/evenings if electric wasn’t available.
4,814
That makes two of us. Even with EHU we have the heat turned down to 16C between 10pm and 6.30am.
4,069
Its up to each caravanner to decide how or if to use heating at night, and whilst there is nothing wrong with turning gas appliances off at night, the frequent references to "I'd never use gas over night" without any explanation of why, leaves the impression that gas appliances are inherently more dangerous at night which is not an fair or accurate perception.
I would only recommend considering using a heating appliance that is thermostatically controlled.
If your concern is products of combustion being a problem at night, then realistically if its dangerous at night, it must also be dangerous at any other time, and it should not be used until is has been made safe. Just becasue you may be awake, does not change the risk.
Gas appliance manufacturers have to go to considerable lengths to include multiple safety measures that provided the appliance and the installation has been fitted, maintained and used correctly, the appliance is no more dangerous day or night.
You might have good reason or preference not to use gas or electric heating at night, but if its becasue someone in the caravan may cause a hazard, such as dropping or allowing clothes or bedding to fall onto the heating appliance, that's not the appliances' fault.
1,080
411
1,435
Old wives tales
The flame temperature of propane in air is 1980 deg C while that of butane is 1970 deg C. or about 0.5% difference. - not worth mentioning.
As for freezing NO. it stops boiling at about 0C as I described above.
Refer to calor gas web pages
2,449
11,935
Like OC and Buckmaan, I used electric heating at night. I may have used gas in the past, but cannot remember doing so.
Despite what the Prof says, I think it is perfectly understandable that some would not feel as safe using gas, particularly at night. Manufacturers may well make every effert to build appliances with safety built in, but the quality of instalation and maintenance are variables.
8,358
Sorry bud no idea..I just found their web site by typing calor gas or try propane v butane there may well take you there 👌Gary
Calor give the boiling points of propane and butane as -42 deg c and -2deg c respectively. So I see nothing incorrect when Prof J says butanes boiling point is around 0 deg c. He’s entirely consistent throughout.. But it certainly doesn’t freeze at 0 deg C as per post #16. The respective freezing points fir propane and butane are given in #19.
4,069
I have done so, but could not find any where that I looked they state
"Also propane burns hotter..butane can freeze at 0.C"
What they do say is that
(https://www.calor.co.uk/propane)
"Thanks to the high octane rating, propane is ideal for heating, as it’s efficient and produces more energy per cubic metre than other forms of fuel."
There are several different ways of describing the energy content of LPG fuels, and that can sometimes be counter intuitive becasue of the number of variables that can affect measurement method. the calorific energy does not directly relate to temperature of combustion.
But as I stated Propane has a flame temperature of1980C in air compared to 1970 for Butane in the same circumstances. Its marginal but all authoritative sources confirm that Propane burns hotter than Butane.
Nov 30, 2022
1,794
1,637
2,935
All modern gas appliances (apart from the cooker before some clever clogs comes along) are sealed and totally isolated from the inside.
Bit I still have both smoke and carbon monoxide alarms
Jul 15, 2008
3,840
989
.....I've used a Carver Fan master circa 1995 at night on a low convection setting (no 12 volt fan running) due to low overnight temperatures.
Once was in Edinburgh for the new year celebrations when the temperature got down to minus 16C.
The sites electrics failed due to overloading so had to use gas...the heater coped and was perfectly safe.
You would be wise to use Propane as already advised.
Sep 23, 2023
1,080
411
1,435
So sorry I got that information from pure lpg they must have it wrong ..
865
Gas is the only source of heat in our caravan and we have no reservations in using it. We have done so for over 30 years.
4,102
In winter, I tend to have our Truma Combi heater set to Gas and 8 amp electric setting, no problems.
2,011
We have the heating turned down to 6 or 8 C in the winter. Thick duvet is plenty. Can’t stand a hot bedroom. I would expire at 16C 😀
mel
3,086
As we get older, we've gradually turned the thermostat up to 16C - any cooler and I'd freeze getting out to go to the bathroom - no point making caravanning into an ordeal.
Reactions: Buckman and Hutch
865
I‘m with you Roger. Besides, I‘d feel uncomfortable being wrapped up in bed just to keep warm. As you say, the way to the bathroom (or a bite into something from the fridge) in the moddle of the night would be rather unpleasant, too. I'd have to find something to put on first, and that probably in the dark in order not to wake anyone else.
4,069
They are part of Birmingham autogas
I have viewed their sites, and I have found the PureLPG comment Here
They say :-
PureLPG say:-
"Butane is a naturally flammable gas obtained from oil refining and natural gas processing. It has a boiling point of 0°C which is right around the same temperature for freezing water."
The word "freezing" relates to water not Butane.
PureLPG say:-
"Propane burns hotter than butane due to its chemical structure, propane – C3H8, Butane C4 H10. Propane has a higher calorific value which means it gives out more energy than butane. Propane has a hotter flame temperature, hence why propane is the preffered fuel for cooking / catering applications (as well as heating)."
Technically correct Propane 1980C vs Butane 1970C, but the difference is so small the man in the street wouldn't be able to tell the difference.
There are several differences between the gasses, which makes direct comparisons technically difficult. The Industry use a special calculation to generate a WOBBE INDEX value for each gas, which indicates the the relative compatibility of different gasses with a view to using them in an appliance.
Broadly speaking Butane at 28mBar and Propane at 37mBar supply pressure will generate the same heating effect. At 30mBar Butane will will provide more heating effect than Propane.
4,814
However I don't think many caravan manufacturers are aware of this snippet of information? :ROFLMAO:
Aug 12, 2023
644
293
1,135
They say :-
PureLPG say:-
PureLPG say:-
Freezing is state liquid goes to solid state. Boiling is when liquid goes gas state which is issue that we discussing in this thread.
Two things that affect boiling point are pressure and temperature. Lower pressure lower boiling point. With gas heater lower pressure means it can't produce max heat.
4,069
That is true, but it doesnt change the flame temperature which was the specific criteria in question. Big flame or small flame the temperature is the same, its volume of flame not its temperature that changes how quickly it will heat anything up.
