Douglas_374404558 said:
I Have a just over 3yr old Bailey Pegasus GT65 Rimini .I have hot/cold water in the large sink in the living area (kitchen) ,I also have hot/cold water at the shower .both as normal .BUT NO hot/cold water coming from the small sink in the toilet . I think it could be the pressure switch at the tap if it has one?. I say that because there seems to be a switch where the inlet for the water pump plugs into the side of the caravan .when I open the sink (kitchen) tap this clicks when tap is opened/closed as it does with the shower pump starts/stops . but does NOT when I open the toilet sink tap hot or cold .nothing . Anyone had same/similar problem . there are no leaks from inlet to toilet taps.
Hello Douglas,
Given the circumstances you describe we can discount the pump and the pressure switch. Just for your information the caravan manufacture will only have fitted one pressure switch by the cold water inlet. Any other wires you may find at the taps are redundant, but may be there because the manufacturer may have used a stock part which happens to have micro-switches for use in caravans with switched tap control system.
What I believe is an important comment is that you report BOTH hot & cold are affected. This would be unusual and unlikely to occur if it was a single tap fault, but the pictures I have seen of the Rimini show a mixer tap in the bathroom. so it is possible the mixer tap is broken or its outlet blocked.
Alternatively as you don't tell us if the tap has ever worked for you, perhaps you have only just acquired the caravan. It could be possible the previous owner has had some problem with the tap or the sink and has disabled the tap or pipe work leading to the taps.
