Nose Weight Gauge
Ern
May 23, 2021
455
211
935
Having read the thread, I didn't think any contribution I would have made would be of interest, so didn't post. More importantly, it's good to see the later post from the OP in which he showed a clear understanding of the whole matter. An educational thread for future readers
4,839
I don',t probably only if I change from One gas bottle to two, or if Mrs H has restocked the kitchen supplies. Probably every 4 trips.
  • Wow
5,581
Me? Once a year. Unless we radically change the internal loadings. Always been within 10 kgs or less.
  • Wow
2,400
May I ask just how many on here honestly check the nose load before each journey?
I carry a nose weight gauge but I only check it if we change the payload.
I tend not to carry heavy items at the front of the caravan apart from the gas bottle.
5,581
And there‘s me thinking you liked the front seat 🤪🤪
  • Haha
Reactions: Parksy
4,839
I have seen the size of your breakfast Buttie. 😀😀
Reactions: Parksy
Sam Vimes
2,834
2,307
12,935
That would be me.
Always surprises me when we're people watching on site, how many people don't check the nose weight when leaving nor adjust their tire pressures after arriving or when leaving.
I always do both.
9,659
I always checked the noseweight before leaving home. On short trips I did not recheck it before returning but when abroad it was checked before departure fir the return trip. Tyre pressures would be adjusted if required for solo driving after arrival on site and vice versa.
951
I checked mine before we left home 6 weeks ago. I doubt whether it has changed more than 10 kg since then. If anything it will be less than when we started as the two gas bottles are slowly being used up.
1,819
I do
My wife has a habit of putting very heavy things at the front of the caravan, just after i think we're all done!
That would be me.
Tell her if she is doing that she needs to ride at the rear to balance the weight at the front.
I always do both.
I check the tyre pressures before going away but I have never had a problem with them dropping when touring. There was one incident where we had a flat tyre when we were about to leave but that was obvious.
Cannot argue with checking the nose weight though as that can be affected by tings used and new things purchased although if the loading is right it should not be a problem.
4,473
Sam beat me to the short answer,
The reason why tyre pressures often need to be increased when towing, is partly due to the significant static nose load that is added to the car - especially the rear axle load, but also when the car accelerates, changes directions, or brakes, the caravan does impart much higher loads through the tow bar, which places considerably higher and loads in different directions through the cars rear tyres and can cause them to squirm.
The higher pressure not only helps to support the static loads, but it also stiffens the tyres side wall to reduce the squirming effect that additional side loads can produce.
5,581
As far as I can remember car manufacturers have always quoted two pressures depending on load. I hope no one has forgotten😉
9,659
My recent Subaru Forester had three specified pressures. One for up to four passengers including driver, second five passengers and luggage, third for towing.
But like most things it could lead to questions such as what is the towing pressure without passengers and minimal load. IE you are collecting van unloaded caravan. What about three passengers, they have luggage but not towing. What pressure is used. So like a number of things caravanning you have to try a few things out to get what feels right. For the Subaru rear pressures at Stage 1 were 220 kp, and for Stage 3 towing 290kp. So I had a wide span with which to work over most loading situations.
951
Not so much a question of the pressure dropping when touring but more a case that the pressure needs to be different when towing compared with driving around when not.
It depends how long you are touring for. I checked the tyre pressure of the caravan tyres the day we left home 25th August and they were 4.5bar (65psi) and today, not quite 9 weeks later, they were 3.6bar (52psi). Could be that back in August the ambient temperature was a good deal hotter than today.
