nose weight measurement
2,893
Welcome to the forum Mossy, looked at both myself. I use bathroom scale every now and again. Pandoras Box has been opened. 😊
Parksy
11,904
2,399
Welcome tothe forum Mossy.
Before a tsunami of technical jargon overwhelms your query I'll launch a pre-emptive strike by advising you that the noseweight should be measured with the caravan hitch at the height of your towball when towing.
You can stand your gauge or bathroom scales on material to raise the head of your chosen device to the correct height.
Reich gauges offer a guarantee of accuracy I think.
Mar 27, 2011
1,332
507
OMG stand by everyone for a absolute deluge of posts by the usual members on this forum who have endless advice on this subject, I hope the original poster has a degree in several subjects to have any hope of understanding more or less any of it.
Reactions: Brasso530
936
If you put Noseweight in the search box at the top left (by the Practical Caravan logo) you will come up with over 10 pages of replies relating to youe question .
Best of luck reading that lot !!!!
Reactions: Brasso530 and Hutch
Oct 8, 2006
1,781
547
I use a Reich and it is within a Kg of my Millenco 'calibrated' gauge.
If you ever did Applied Maths at school as I did you will know that the 2-3in or so difference in height caused by the insertion of the Reich makes next to know difference.
Sep 5, 2016
928
119
4,935
When I use a nose weight gauge I use the Millenco nose weight gauge it is accurate enough for my needs and I would recommend it to anyone who was thinking of buying a nose weight gauge,
Reactions: Parksy and DaveA1
3,585
My Reich is still accurate and easy to use. There are two models , one for a ta and one for a sa.. I'm off this one before the bomb goes up
6,281
I initially used the bathroom scales which a very accurate according to airport check in success. Then I checked the reading from the scales using my Milenco gauge and it was within a couple of kilograms. So after that I just use the Milenco as it’s far more convenient to use and carry around if required. I’m one of those sad people who used to check noseweight on the return journeys from Europe. :)
3,454
32,935
We had the Reich and although accurate you need to be careful. Our caravan rolled about an inch and snapped off the head. We now use the heavy duty Milenco nose weight gauge as our nose weight is rated at up to 150kg.
