- Jun 20, 2005
- 20,389
- 5,551
- 50,935
Since we last done this topic to death I have experimented.
For donkeys years I used the bathroom scales Heath Robinson style but never progressed to Sproket's or Gagkev's engineering masterpieces.
It worked no problem.
Then came the coilspring Milenco. That seemed ok as we always pack the van the same.However many spurious readings were obtained dependent on being level. The pressure from my little finger could cause a 30 kg variance. It's long been binned.
The TA Reich which fits between the towbar and hitch does give me good accurate readings when tested against the bathroom scales. I can assure you all using the EU parameters different readings are obtained from low to high.
Rarely on these debates do we think about the tow ball towbar manufacturer limits on the nose weight as indeed do the two main caravan hitch chassis manufacturers limits.
There is also a factor which I think should be allowed for and that's suspension sag . ie the point about which all your towing will be done.
I'm lucky to have self levelling suspension. With the caravan hitched it is level but using the Reich we are nose up a few mms. Here is where a call to Reich tell me their gauge takes this into account and gives an accurate reading .
Compared to the bathroom scales the variance is less than 5kgs.
Sadly the forumites on here are the minority. It's those once a year holidayers who don't bother.
