"Thingy" has (According to his post script) a large Mitsibushi Shogun which has a nose load capability of at least 140kg. With that in mind is stated method of assessing nose load by feel may be adequate, because of the large nose load margin of the vehicle. Adequate it may be but it's far from accurate.
Many caravanner's do not have the luxury tow vehicles with massive nose load capacities like the Shogun's. Many caravanners use domestic cars. You must check your own towbars specification but most fall between 50kg and 80kg, with 75kg being a modal value.
With such a restriction the uncalibrated human being is entirely the wrong way to assess nose load, and a more competent method should be used such as I have described.
Woodentop said:
I have to argue with the Prof. We are not into great accuracy here and the difference in height will account for no more than a Kg or two, so set the weight to be, say, 3-4Kg below your hitch limit and you won't go far wrong.
I'm Sorry Woodentop, but the amount of variation is dependant on how the caravan is loaded,and it might only be as small as a couple of kg, but equally it can be as much as 10kg. And the effect for twin axles is much more pronounced and sensitive.
Parksy, Yet again you raise the excuse for not attempting to be reasonably accurate because there are no reported instances of prosecutions for excess nose load. That does not preclude the need to try and comply with the nose load regulations.
For the well covered reasons I have explained on many occasions NONE of the retail gauges all the user to measure in accordance with the regulations, principally because the do not preserve the correct measurement height, and thus are not fit for purpose, yet alone for also being notoriously inconsistent and inaccurate.
The method of using a pole with bathroom scales, will only be accurate if you can match the pole length to the towing height for each measurement. This method is also hazardous as the pole is not particularly stable so for safety I prefer to recommend the use of caravan step with magazines to pack the bathroom scales for correct towing height.
Whilst there is a legal side to nose load compliance it is also a matter of safety - so why use a wholly inappropriate method when a relatively simple, cheap and more accurate process is available.
