Number plate holder.
Mar 2, 2010
1,231
6
19,185
Have two cars that could tow van,is there anything available to swap plates easily.At the moment one is fitted by dealer and I pop the other on top with foam tape that comes off easily.But I only use the second motor to pick up from storage at the moment and I will be going furthur hopefully so need something more secure.
Thanks for any assistance
2,940
HGV trailers often have a channel on three sides so that the tractor-unit's reg plate can simply be slipped in.
Mar 2, 2010
1,231
6
19,185
I did buy a chrome plastic number plate holder from Lidl thinking I could swap plates over by undoing a couple of screws but it won't fit in the recesss on our Indiana.Its tricky to work out something secure but easy.Thanks anyway.
Mar 2, 2010
1,231
6
19,185
Following your post RogerL I found these on fleabay,am wondering if these fixed with Sikaflex would be strong enough,what do you think?
http://www.ebay.co.uk/itm/Maypole-Number-Plate-Holder-Allows-you-Switch-Plates-/120678553073?pt=UK_Trailers_Transporters_Parts&hash=item1c190095f1
Apr 7, 2008
4,909
I use a very heavy duty velcro It was advertised in one of the mags, I have three strips on the back of each plate & they line up with the ones on the van, a firm press & they lock together & a wood spatular up the back to prise apart when the other plate is required to be put on
This is the stuff from 3M, they call it Dual Lock Fasteners
Apr 7, 2008
4,909
Can't see why not, they stick roof mounted sat dishes on with the stuff
Mar 2, 2010
1,231
6
19,185
Hi Sir Sproket
Might give that velcro a shot first as it isn't obvious whereas those clips might be seen and plate theived
Best wishes
2,400
Sikaflex is what I used to bond my solar panel brackets to the caravan roof so it should hold the number plate bracket.
The dual lock velcro should be ok though Dave, I used ordinary domestic type velcro to hold the plastic surround of our microwave oven in place and it does the job with no problems.
Aug 25, 2010
167
I used velcro on my old caravan and it lasted for aver ten years with no problems. Don't be tempted to use a massive amount as it is then difficult to swap the plates over. I had two strips vertically about 5 cm from the ends of the plates.
Aug 9, 2010
1,426
As above! Cheap and simple.
3,931
Thats whats coming your way, 2 Pints and a glass of pino for the other half. :p
3,931
DD, posted today 1.5 metres. You have to push it together hard, .
Hutch.
