one shot nuts
Apr 7, 2009
13
I stand corected Damian - I got my CO's mixed up.
But agree that the test should be done - you would have your home gas central heating boiler serviced every year to keep you safe - so why not your caravan's gas appliances ?
The average car does around 12,000 miles per year, and is (generally) serviced once in that time.The average caravan does perhaps 2,000 miles per year (OK, I know some do more, mine included), and is much less complex, so why does it need to be serviced every year? If the brakes weren't worn last year, why should they be worn only 2,000 miles later?
It's a huge caravan industry con, to rip off owners who don't know any different.
This opinion is built on over forty years caravanning.
Mar 4, 2006
265
Hear, hear!!!!
Mar 10, 2006
3,260
44
emmerson
i totally agree, its not a if you get a proper service.
i stood and watched during two services, very little is actually done.
This year i am not having a service, only did 1000 miles last year. not done any so far this.
Feb 16, 2009
1,144
You do realise that torque wrenches have to be re-calibrated and certificate issued, before l retired it was every two years at the company l worked for.
It is an Health an Safety requirement.
NigelH
Feb 16, 2009
1,144
Lutz, might be so but we all have a duty of care to do things correctly, a inspectors first question would be who maintained the van and what with.
NigelH
650
lutzschelisch.wix.com
Agreed, if torque, or rather lack thereof, was thought to be a possible cause, then questions could be expected but I doubt whether a nut which was torqued with an uncalibrated wrench would normally be that far off that there would be a danger of the nut loosening itself. That would really be exceptional.
Nov 4, 2008
147
NigelH
yea it still is every 2 years, the draper torque wrenches come calibrated correctly gauranteed for 1 year like all others, as long as the wrenches are,nt abused ive rarely found a inaccurate one unless its an oldie with many years use, I worked in the trade 30 years and none of the companies i worked for at home or abroad had their wrenches calibrated at a test centre. I once worked for northumberland county council, and their wrenches were away to test bi yearly strictly.
Sep 24, 2008
919
238
19,135
You can go on the web and by quoting calibrate torque wrench you will find this and other persons that tell you how to calibrate. The one i copied worked out fine , it showed mine out by 5 lb, for instance if i wanted 65 lb i adjusted to 60 and that gave me the right torque.
Aug 28, 2005
1,318
am i to understand that if i get a puncture and use the spare tyre i cannot use the the wheel nuts to put the spare back on or should i carry a spare set of wheel nuts
avril
Hi Avril,
Just to add to Nigels answer.
I have a Burstner caravan fitted with alloy wheels. I have been issued separate wheelnuts for if I should have to change to my spare which is steel.
I was informed that the taper on the shoulder of the nuts are different for alloy wheels and steel wheels.
British built vans do not come with wheelnuts for the spare wheel, so if you use the origional nuts for the alloy wheels on the steel wheel you risk damaging the wheel / wheelnut and the wheel coming loose.
i also got 5 bolts for the spare steel wheel on my Lunar Lexon,allthough there is no mention about them in the hand book
Feb 16, 2009
1,144
l gree with you Lutz if the wrench is a reputable make and not one that does not come with an origanal cert.
l have seen the cheaper models don't have calbrated cert that should be provided at purchase and if its from the far east would not have a Declaration of Conformity like here in Europe.
NigelH
Jun 11, 2012
1,523
23
19,685
I must be the luck one here ,I use a mobile fitter for servicing our van and have to say a very good one at that.
He never charges for the one shot nuts and prides himself in telling you they are free. Now I have been bought a T/A he may charge now hes got 4 to give away in one hit
Sir Roger
Hi Everyone,
I wonder if someone would kindly answer Graham South Brum's question please as I am very interested in the answer re-re-use of wheel nuts .Many Thanks.Jimbob
Mar 10, 2006
3,260
44
Jimbob
My bailey has the steel spare wheel, the van has alloys.
Bailey use wheel bolts, bailey have told me the bolts are to be used with the spare.
G
Guest
Just a quick reply to Ray.
I worked as a motor mechanic in the 60's and it was not usually my vehicle that I was trying to get the b....y split pins off. There was also 'instructions' in many manuals that at least one part of the cotter pin had to be bent through 90 degrees to ensure it did not come loose. The last thing I ever wanted was for an accident to occur through my 'negligence'.
I actually quite like the 'one shot' idea as at least you get a new nut each time. Also the torque these have to be tightened to is usually outwith the remit of the average home mechanic, and maybe that is a good thing, although I admit not all mechanics are to be trusted.
Lutz,
I am sorry I got that wrong about the type of nuts,what you must remember is that we are all not technically minded as you and so a little explaining and patience is required.Thank You.Jimbob
Dec 22, 2008
85
i thought one shot nuts were used because the threads were tapered and the nuts would be stretched. they have been using one shot bolts for cylinder heads on cars for years.
650
There are several types of one-shot nuts, but they all have one thing in common, they are self-locking. The most common variations of self-locking nuts are nuts that have been pressed slightly oval, nuts with plastic inserts or nuts that have tooth-like serrations on the underside that dig into the parent material.
Nov 29, 2007
667
The truck dealer I work for has all types of measuring equipment, including torque wrenches, calibrated every 6 months. You would be surprised how many fail the test. Having said that, they do get heavy useage.
Jun 2, 2017
141
yeezy boost 350
jerseys cheap
coach outlet online
heat jerseys
phillies jerseys
cowboys jerseys
hermes bags
discount nike shoes
oakley sunglasses outlet
michael kors outlet store
louis vuitton bags
yeezy boost
mont blanc pen
michael kors outlet
adidas uk
birkenstock outlet
louboutin pas cher
nike outlet
toms
burberry outlet online
kate spade handbags
purs jerseys
adidas outlet store
cheap jerseys
toms
coach factory outlet online
cheap nike sneakers
nfl jerseys
louboutin outlet
longchamps
air max outlet
ralph lauren sale
adidas running shoes
coach handbags outlet
birkenstock shoes
coach outlet online
true religion
pandora charms
fitflop shoes
nike outlet store
ralph lauren outlet
adidas nmd r1
yeezy shoes
air max
nike outlet store
coach outlet online
michael kors
coach outlet store online clearance
hermes bag
kate spade bags
moncler uk
versace
cheap jordans for sale
prada outlet online
ralph lauren outlet online
louis vuitton factory outlet
gucci borse
mont blanc pen
swarovski sale
coach outlet online
kate spade outlet online
mulberry uk
coach purses
jordans
tory burch outlet online
adidas outlet online
giants jerseys
adidas nmd runner
gucci outlet online
adidas nmd runner
adidas outlet store
yeezy boost 350
beats by dre
rolex replica watches
nike outlet
moncler uk
gucci handbags outlet
ralph lauren sale
coach outlet store
kd shoes
cheap jordan shoes
polo ralph lauren outlet online
sac longchamp
burberry outlet store
ralph lauren outlet
kate spade outlet store
harden shoes
pandora jewelry
pandora charms sale clearance
michael kors handbags outlet
polo ralph lauren
christian louboutin
dansko outlet
texans jerseys
ralph lauren sale
fitflops
fendi bags
air max 90
dodgers jerseys
eltics jerseys
louis vuitton outlet online
longchamp bag
rolex replica watches for sale
chaussures louboutin
nike free 4.0 flyknit
rolex watches
coach outlet store
yankees jerseys
montblanc
pandora charms
fitflops sale clearance
pandora
coach outlet online
nike free run flyknit
nfl jerseys cheap
curry shoes
ray ban sunglasses outlet
christian louboutin outlet
adidas nmd runner
nike air max 95
marc jacobs
christian louboutin shoes
adidas ultra boost
ray ban sunglasses discount
cheap jordan shoes
adidas superstars
hermes outlet online
oakley sunglasses on sale
cardinals jerseys
michael kors outlet clearance
abercrombie outlet
marc jacobs outlet
hermes outlet
cheap rolex watches
pandora charms
air max 90
nike free run
nike outlet store online
longchamp handbags
yeezy boost
true religion jeans
ralph lauren sale
tory burch sale
coach outlet online
fitflops clearance
air max
cheap jordan shoes
michael kors outlet online
nike sneakers
coach outlet online
yeezy boost 350
louboutin outlet
coach outlet online
gucci outlet online
air jordans
coach outlet store
discount oakley sunglasses
moncler pas cher
polo ralph lauren
mulberry bags
sac louis vuitton pas cher
coach outlet online
ray bans
michael kors bags
adidas
toms outlet
coach outlet store
michael kors
mont blanc pens
broncos jerseys
sac louis vuitton
birkin handbags
swarovski uk
fake rolex watches
clarks shoes outlet
wireless beats headphones
salomon boots
birkenstock outlet
ralph lauren
jordan shoes
fit flops
coach outlet store
louis vuitton outlet store
adidas nmd r1
gucci
red bottom shoes for women
mulberry handbags
adidas nmd r1
christian louboutin sale
swarovski crystals
ralph lauren outlet
rangers jerseys
mulberry outlet uk
mlb jerseys
true religion jeans outlet
pandora jewelry outlet
fitflops clearance
beats wireless headphones
burberry sale
bercrombie
tods outlet
fitflop shoes
cheap nike shoes
cheap nfl jerseys
kd 8 shoes
salomon outlet
nike outlet online
burberry outlet
michael kors bags
jimmy choo shoes
ed hardy store
fred perry polo shirts
cheap oakley sunglasses
valentino outlet
pandora charms outlet
air max shoes
nike store
dolce and gabbana outlet online
yeezy boost
toms outlet
fitflops sale
michael kors outlet canada
nike roshe one
gucci
49ers jerseys
moncler jackets
mbt
michael kors
ralph lauren outlet
adidas
yeezy boost 350
nike air max
yeezy 350 boost
michael kors bags
ralph lauren
patriots jerseys
adidas nmd r1
michael kors uk
coach outlet online
nike blazer low pas cher
pandora bracelet
nike air max 95
red sox jerseys
gucci bags
coach outlet online
air jordan shoes
nike flyknit
christian louboutin
mulberry uk
moncler outlet online
levis outlet
toms
nike roshe shoes
longchamp soldes
longchamp outlet store
hollister clothing
coach outlet canada
lakers jerseys
kate spade uk
longchamp bags
michael kors
ralph lauren sale clearance uk
moncler jackets
chi flat iron
jordan shoes
hermes bags
polo ralph lauren
mulberry
ralph lauren
clarks shoes outlet
coach outlet online
nfl jerseys
coach outlet
michael kors
mlb jerseys
adidas sneakers
longchamp bags
adidas store
hollister kids
beats headphones
nike cortez classic
tigers jerseys
warriors jerseys
pandora jewelry
salomon outlet
cheap air jordans
longchamp pliage
nike air force
michael kors outlet
louis vuitton purses
michael kors
nfl jerseys wholesale
adidas superstars
packers jerseys
longchamp handbags
fitflops sale
michael kors
red bottom
pandora outlet
white sox jerseys
fitflops sale
mbt
air max
clarks
nmd adidas
cheap ray ban sunglasses
coach outlet online
adidas yeezy boost 350
burberry outlet
cavaliers jerseys
air jordans
adidas sneakers
true religion outlet online
fred perry shirts
adidas trainers
polo ralph lauren pas cher
cheap jordan shoes
pandora jewelry store
red bottom heels
eahawks jerseys
ed hardy outlet
coach outlet online
louboutin shoes
nike uk
clarks shoes for women
parada bags
longchamp sale
yeezy shoes
bulls jerseys
moncler coats
nike outlet store
vans outlet
vans store
timberland boots outle
ray ban glasses
christian louboutin pas cher
cheap jordan shoes
rolex watches
jordan retro
yeezy boost
oakley sunglasses wholesale
nike tn pas cher
jordan femmes pas cher
rockets jerseys
cheap rolex replica watches
adidas nmd runner
montblanc pens
coach outlet online
gucci bags
birkenstock uk
adidas yeezy boost
thunder jerseys
jordan uk
louboutin outlet
birkenstocks
sac longchamp
ghd straighteners sale
adidas yeezy boost
coach outlet online
fitflop
adidas yeezy boost
birkenstock
celine outlet online
air max 90
fitflop
birkenstock outlet
ed hardy clothing
nike sneakers
fit flops
louboutin shoes
ray ban sunglasses cheap
ed hardy uk
adidas trainers
ralph lauren
chaussure louboutin pas cher
ghd hair
nike air huarache
ray bans
yeezy boost 350 v2
ray ban glasses
coach outlet online
coach factory outlet store
adidas superstar trainers
michael kors
polo ralph lauren
adidas superstar shoes
mlb jerseys whgolesale
pandora charms sale
tods shoes
birkenstocks
celine handbags
yeezy shoes
red bottom
kate spade outlet
kate spade bags
mbt
fitflops sandals
mlb jerseys
coach outlet online
cheap air max
longchamp bags
dansko
adidas sneakers
michael kors uk
adidas yeezy boost
cubs jerseys
ralph lauren uk
coach outlet online
fit flops
louboutin outlet
kate spade purses
pandora charms sale
dwqdwq
