- Jun 20, 2005
- 19,463
- 4,913
- 50,935
DIY £20. Powrtouch parts and fit £70. Took the cheap route. Fool!
So got the Wyoming high in the air , triple safe on boards and tipped sky high. Removal of the mover should be like dismantling a meccano kit. Wrong! One nut on one of the U Bolts wouldn’t budge. WD40, Plus Gas no good. Heat gun worked , just. New U bolt and nut set arrives tomorrow, £20 for both sides. Next time no messing, cut them off with the angle grinder. They have been in situ 10 years.
Outer roller bearing is all balls :woohoo: Inner race holding the roller needed plenty of persuasion . It came off but only the outer cage and balls. Now I cheated. Down to the local engineering shop to remove the old inner bearing housings and press the two new bearings into place. Pick up tomorrow and then refit. It was very hot today so after dropping the bits off at the engineers visited the local hostelry for a few beers.
Costs are now mounting, my back is aching and I still have tomorrow’s work to face.
Next time I am paying £70 a side and relaxing
:cheer:
