Parksy said:Yes, I have them. Not much to say really, exchanging batteries is quick and easy
chrisn7 said:Don't bother with those nasty blue and red lift up jobbies - they corrode and are almost impossible to clean up.
chrisn7 said:Don't bother with those nasty blue and red lift up jobbies - they corrode and are almost impossible to clean up. I use a side lever type which has adjustable clamping force, plus a second terminal for your mover power leads if the battery doesn't have these. Their height is the same as the battery terminal too.
I'd post a link, but I can never make one work either
Anseo said:chrisn7 said:Don't bother with those nasty blue and red lift up jobbies - they corrode and are almost impossible to clean up. I use a side lever type which has adjustable clamping force, plus a second terminal for your mover power leads if the battery doesn't have these. Their height is the same as the battery terminal too.
Hi chrisn7,
Wish you could post a link as I am interested in identifying the product you refer to, perhaps Parksy can help you, he is a good chap 🙂
If you scroll down to the Our Website message board I said:Parksy,
Where is the Website message board?
I acknowledging in advance that I most probably am having a 'tense and dense' moment :blink: in not being able to locate your sticky re URL postings.
Ta.
Parksy said:Anseo said:chrisn7 said:Don't bother with those nasty blue and red lift up jobbies - they corrode and are almost impossible to clean up. I use a side lever type which has adjustable clamping force, plus a second terminal for your mover power leads if the battery doesn't have these. Their height is the same as the battery terminal too.
Hi chrisn7,
If you scroll down to the Our Website message board I've added a sticky post containing step by step instructions on how to post links
Auspom said:I found something similar in usa but the locking lever goes vertically not sideways.
WoodlandsCamper said:Is this the horizontal ones? click here
Anseo said:Apologies and thanks to Gagakev 🙂If you scroll down to the Our Website message board I said:Parksy,
Ta.
The Our Website message board is at the bottom of the Index webpage but to save you looking for it Click Here
chrisn7 said:WoodlandsCamper said:Is this the horizontal ones? click here
Yes! those are the ones - well done WC. Just be careful to observe polarity with them being the same colour.
