Lutz
Appreciate your comments. Please consider this as well.
I have hydraulic disc brakes on the boat trailer (american import) which perform faultlessly. They are vastly superior to the cable actuated drums on the caravan. Yet still they are technically illegal, mainly because of the lack of attention the law gets in these areas. Seems to me like the dinosaurs in Westminster need to move into the 21st century before the rest of us can.
Canbus could easily be used and a common transmitter is another easy one. Just think back to when we all had points & condensors. The industry soon developed electronic ignition retrofit kits. Plus of course, if canbus were to be used there would be plenty of spare pins in the socket. the CAN could be used to trigger all the various road lighting functions which frees up about 7 pins.
The main thing to consider is that articulated lorries don't need stabilisers mostly due to the fact that the trailer brakes are directly linked to the brake pedal. There is also the fact that the trailer can weigh over 6 times the kerb weight of the tractive unit, something we are all told is bad in a caravan. I contend that it is only bad because of the prehistoric braking systems on caravans. If we had a decent and more "connected" system for braking then stabilisers would not really be so important.
Let's be honest, the larger single axle vans can weigh up to a tonne and a half and yet still legally rely upon one set of drum brakes to stop it (with a LOT of help from the tow car) That's not good in any language.
Plus of course, once we do get better braking systems which are more connected to the tow car, such stability devices as the sophisticated electronic ones we are starting to see now would simply become another module on the CAN BUS and therefore cost a lot less. We might even end up with ABS on our vans !!
This ATC system seems like good news to me, for now at least until we get type approval on some more modern brakes.
I guess for now I'll stick with the ALKO friction hitch despite the fact I have to clean the ball every time I've pulled the boat. Yes it's only 30 seconds with a rag and some thinners but still mildly irritating.
