Recommended Buys!
Sep 12, 2024
38
35
Evening all!
Just back from our second weekend away in the caravan, complete newbies so completely unaware of what’s available to make life easier when touring.
Connected the aqua roll up yesterday but we were on a fully serviced pitch and I thought “wouldn’t it be a good idea if there was something you could use to connect the caravan directly into the water tap?!”
Fast forward to today when I found out that there is such a thing and that it’s also possible to connect the grey waste on a fully serviced pitch in a way that stops me from needing the wastemaster.
Both would have saved some time during our stay.
Anyone have any other suggestions to handy things you’ve bought or other ways of doing things?
Sep 12, 2024
38
35
Never had any issues with the shower yet touch wood and the only thing we’ve needed a USB port for would be our phones but we’ve got a wireless charger inside the caravan so all good!
Thanks for the suggestions
Reactions: Beardy
9,331
Got and got! We did realise this weekend we need some stacking blocks for the caravan legs if anyone has any recommendations?
I used Milenco ones but there are other makes very similar such as Carastack.
If you can find a pair of Bebbington Leg Extenders they are brilliant but the company no longer make them. But occasionally they pop up on EBay.
5,362
We have four of these blocks even though er have self levelling and they have saved our bacon on more than one occasion. HERE.
Reactions: Mel
9,331
Here is a picture showing the Bebbington leg extenders on the front steadies. They widen the footprint of the caravan
2,300
A card holder on an extending arm. Invaluable if, like us, you have a card entry system to storage. Also handy if you use the M6 toll or when not towing and using pay on exit car parks
Like this one
Sep 12, 2024
38
35
Thinking about the stacking pads, before we had the caravan everything I read was saying to never use the legs as the levelling mechanism as they’re only designed to support the caravan when it has been levelled. Using stacking pads is going against that surely?
Is it ok to use these to level the caravan off or should ramps or another item be used?
May 30, 2024
116
136
635
You're never going to use the corner steadies to level the van. Always ramps under the wheels first, then front-to-back with the jockey wheel.
The need for pads, or stacking pads, or leg extenders is just about compensating for the different ground conditions when you're not on a levelish hardstanding pitch. So, maybe some plywood squares to spread the load when you're on wet ground or soft grass. Or, possibly, stacking pads for when you're on a really sloping pitch and one or other of the corner steadies won't reach the ground even when fully lowered. But in my experience, if the site is quite slopy then you will find convenient bricks or concrete blocks left around by the site owners, and a concrete block is going to be a great deal more stable to wind the steady against then anything in moulded plastic. For sure, being prepared is a good thing. But it would be madness to carry some concrete blocks with you just in case.....
If the site is very sloped, such that one end of the caravan is a long way off the ground, you probably won't sleep anyway, for dreaming about whether its going to roll away in the night. Better to move to a different location..
9,331
Never use corner steadies to level the caravan. It’s ramps, blocks of wood, air bag levellers, wind up levellers etc and jockey wheel.
1,310
1,167
2,435
+1 Milenco stacka jacka pads they were brilliant and very reasonable .
Agreed, I used to use several blocks of 8" x 2" wood (off cuts from the roof of our garage) but switched to Milenco pads when I decided the caravan needed to shed a few kilos!
Mar 3, 2022
416
334
4,935
Leveling? No contest! Lock n' level every time 🤓
Few offcuts of 4x2 timber in case you need to boost the steadies by a few inches.
Reactions: Challenger
