• Weโ€™re currently investigating an issue related to the forum theme and styling that is impacting page layout and visual formatting. The problem has been identified, and we are actively working on a resolution. There is no impact to user data or functionality, this is strictly a front-end display issue. Weโ€™ll post an update once the fix has been deployed. Thanks for your patience while we get this sorted.
Recommended Buys!
With all these ideas - a base line weight for the van. Take it to a weigh bridge, and find out how much payload you _really_ have before you are overweight.
It's amazing how quickly it gets used up...
Did that recently and discovered I was lot more overweight than expected. Switched to a LiFeP04 battery fitted with anderson connector so it is quick to disconnect. That now travels in car, which reduced weight in van by 28kg compared to AGM. Another 17kg by throwing spare wheel in car.
We went from Pb to LiFePO4 and saved about 10KG. It lives under the floor under the bed so we dont take it out to travel. However, if we need the additional van payload, the spare wheel does come out and ride in the car boot.
Various sizes and lengths of string and rope are always useful at some point. They take up so little space but can be worth their weight in gold.
Of course, learning to tie a few significant knots may help a great deal at some point.
My two favorites for general use are the 'Prussic' knot, and the 'Truckers hitch'.
The prussic will take you 5 mins to learn, and you'll probably always remember it...... The truckers hitch may take a few minutes longer and require a good few repetitions.
There are thousands of other knots but these have gotten me out of a fix on several occasions, so I recommend them highly.
YouTube is the best learning resource for all things knotty.
