Renovating ABI Marauder
Apr 1, 2022
Renovating an ABI Marauder around1998 vintage. Can only find one shut off valve for gas but it appears to be just for the fridge. Any ideas where i can find the others?
1,325
Hi Ken. Welcome to the forum. Can’t help you, I’m afraid. Hope someone here can.
mel
1,792
Hi, welcome to the forum. Sorry we have not had a Marauder so cannot be sure where the valves are but if you can follow the pipes you should find them. I think if the fridge has one there will be valves for the others unless you have one valve for everything.
You will find the handbook for this model is generic to the whole ABI range for each year. If you google caravan handbooks you might get one and that will hopefully show the location of the valves and will help with other work.
At the same time are you sure that this is a 1998 model as the model was dropped by Swift before then. According to the Go Caravanning records it ceased production in 1996, although there were Gold, GTE and Sportique models for 1997. Do you have a serial number for it and someone might e able to give you a date?
