I am still using MS Autoroute 2001 and it is now a bit dated and I would like to upgrade but not to Autoroute 2013 which has got many bad reviews. Can any one suggest an alternative to MS Autoroute? Thanks.
clearly there is a reason why you want and use MS autoroute ......the alternatives given are all cheap sat nav based routing which is fine for piont to piont routing and nothing more.. So what are you after Surfer Given your previous use of Autoroute?Surfer said:I am still using MS Autoroute 2001 and it is now a bit dated and I would like to upgrade but not to Autoroute 2013 which has got many bad reviews. Can any one suggest an alternative to MS Autoroute? Thanks.
JonnyG said:clearly there is a reason why you want and use MS autoroute ......the alternatives given are all cheap sat nav based routing which is fine for piont to piont routing and nothing more.. So what are you after Surfer Given your previous use of Autoroute?Surfer said:I am still using MS Autoroute 2001 and it is now a bit dated and I would like to upgrade but not to Autoroute 2013 which has got many bad reviews. Can any one suggest an alternative to MS Autoroute? Thanks.
