Sensitive TPM,s
Feb 13, 2024
1,392
883
1,435
My 68 plate sportage tpm,s are very sensitive, one wheel dropped 1 psi, suspect due to cold weather and threw up the dashboard warning ⚠️ light. Anyone else have the same?
9,261
Never had that occur on any car fitted with TPMS. As the weather seasons change I adjust the pressures accordingly but 1 psi seems overly sensitive.
Reactions: borderbilly
3,686
It's not TPMS sensitivity - it's Boyles Law - the tyre pressure will naturally drop 1 psi for each 6 degree C drop in temperature - some places have had a 12 degree change from last week to this.
5,425
My VW is the same . The TPMS soon goes off as the tyres warm up. Or do as Clive suggests increase all by 1.
Reactions: RogerL
Mar 13, 2024
7
515
I've had a few Kia, s and the tpms are very temperament. Had to increase a few 5/6 psi to get the dashboard warning light to go off & then a few days later lower to correct pressure. Very strange indeed
Sam Vimes
2,700
2,159
12,935
What you don't state is how close to the lower limit the tyre was before the temperature dropped.
Sep 4, 2011
639
394
19,135
When winter cold starts all tyres need checking whilst still cold and inflated to the correct cold pressure. Then in the menu set them. Unless it comes considerably colder no Tyre Pressure light should come on again. If they are just left at summer setting they are prone to come on until traveled some distance to warm the tyres up.
Sam Vimes
2,700
2,159
12,935
Mine are set to 33 all year round but a couple of days back the temperature was just below 2degC and the TPMS reported 31psi but no warning was set.
Sep 4, 2011
639
394
19,135
Then general rule for tyre pressure is 2 psi for 10 degrees differential. So if Winter temperature when cold is 10 degrees lower than the tyre cold pressure in Summer they need 2psi adding to prevent the monitor light coming on.
9,261
I just set mine at 33psi all year around depending on weather conditions in summer or winter. Never had any spurious lights ever.
