Actually it does seem that not even the technician needs a damp meter.I must have missed something. Whilst I look at me seals I have never visually seen a failed one. It is so hard to examine every screw on the awning rails etc never mind the hidden joints by the floor and behind the wheels windows and roof straps,
Not all of us can afford a non invasive moisture meter like the Protimeter. Using one with probes may leave indents al around the caravan.
Just a quick go around of the corners of the caravan, and other prominent points with a damp meter, every three month will help you know if you have a small pinprick leak in joins etc. That are hard to see.
Buckman you don't go sticking the pinned type in visibly obvious areas, around windows, just lift the seals slightly. Doors are the same.
Around toilets on the floor , anywhere that the carpets cover.
The final use is down to the owner, I can hardly see where I check my caravan.
