skoda kodiaq towing capability HELP!!
9,532
From a practical standpoint the axle will not fail at 1Kg over its rating - 10% would at my guess be a reasonable overrating. An uprated van will usually take you to or close to the axle limit - as is the case with my Unicorn S4 Seville and it would be unsafe to do that if the axle failed within a few Kg of that figure.
I inadvertently overloaded a 1000 kg MTPLM Trigano pop top to near 1250 kg. The tyres were rated at slightly above 1250 kg as before I bought it home I’d had uprated tyres fitted, but that wasn’t because of an intention to overload it. In mitigation all I can say is that the public weighbridge in Brecon confirmed that my careful weighing of the payload was within 10 kgs or thereabouts. It towed well, no bouncing around.
Reactions: JezzerB
940
If the manufacturer has done his homework properly, the axle limit will take into account a certain percentage of towing over unsurfaced roads and Belgian pavé. Under such conditions the dynamic axle loads will be a lot more than the 10% margin that you consider appropriate.
