- Nov 11, 2009
- 25,072
- 9,067
- 50,935
So would it be best to give every house its own wind turbine, solar panel with a couple of ex Tesla batteries and a composting toilet with attached biogester. 🤣
Hi Clive don"t mind wind turbine solar panel and ex tesla batteries but i give the toilet composting a miss thanksSo would it be best to give every house its own wind turbine, solar panel with a couple of ex Tesla batteries and a composting toilet with attached biogester. 🤣
Actually not a bad idea, but lithium batteries are probably better than any Tesla battery. If they were able to use the wind to generate power to a home in South Africa over 50 years ago using small windmills with our modern 1st world technology it should not be a problem.So would it be best to give every house its own wind turbine, solar panel with a couple of ex Tesla batteries and a composting toilet with attached biogester. 🤣
The ones I saw in SA had a circumerance of about 3 foot and were normally on a small lattice mast. Charged a few batteries and only lights used for electric. No need for heating except for hot water which was normally done with gas. The alternative was wood in a burner for the hot water.Some years ago a neighbour fixed a wind turbine to his gable, about 3ft diameter. It didn’t last long. Too noisy and it shook the whole house.
Can you please explain your last statement?
We had an old cottage in Dartmoor. It was two knocked into one and comprised the end of a row of miners cottages. We had a coal fire at the “detached” end of the cottage and in our dining room we had a gas fire built into the original chimmney, which also since we adjoined the next door property served as their chimney too, but the chimneys serving each were of course seperated. That is until stones started to fall out. But when the neighbour lit their coal burner it warmed our dining room and the wall of the bedroom above. Similarly the coal fire in the lounge not only heated the lounge but the end wall of the main bedroom too. So in winter both ourselves and our neighbours tended to keep the coal fires going pretty well continuously so the gas central heating was only used for those rooms not benefitting from the large areas of warm walls heated by the coal fires. It was very cosy, with endless supplies of hot water.The concept of thermal capacity is often neglected when property heating is being designed. Insulation is easy to understand. But in ideal circumstances both go hand in hand.
As an example. Consider an old property with solid, uninsulated walls. The only heating is an open fire. Come winter, the fire is lit. Very little heat is felt for about 4 days. Very inefficient in many ways. But most of the heat is absorbed into the breast. This mass holds a considerable amount of heat which then helps to smooth out the yo-yo effect.
To compare that to a modern well insulated property. Probably dry lined on insulting blocks then a cavity possibly insulated. Now there is only the air to heat up which is comparatively easy. So easy‘ish to heat, but cools quickly. (yo-yo).
Ideally, the internal walls need to be heavy construction for good capacity, with good external insulation.
This is well known and documented. The problems are twofold. Wall thickness taking up precious land. and cost.
Consequently, new builds are a compromise. And insulating older properties is not as easy (except for the obvious loft and windows), as many think.
Thank you for your more detailed explanation. I agree, and its a concept that has been previously discussed a long time ago concerning the thermal mass of a caravan vs thermal mass of the air and its been compared to domestic properties.The concept of thermal capacity is often neglected when property heating is being designed. Insulation is easy to understand. But in ideal circumstances both go hand in hand......
My new build flat is extremely well insulated, in fact too well for my liking. It has taken literally weeks to get the average temperature down after the summer heatwaves. Even when the temperatures dropped you could fling the windows open at night and get down to a sensible 21 degrees, shut them at bed time, back to 25 / 26 by the morning, even when it’s only 18 out. And I’m ground floor, I dread to think what it’s like upstairs. Finally got down to about 21 and planning to hold off the heating for as long as possible.
Paraffin now at 12.99 for five litres. No more over wintering plants.Candles are now in short supply, Calor gas and paraffin heaters are in high demand. We purchased two hot water bottles and throw overs gas heated kettle. Good old diesel fuels my car . We‘ll be ok🤪
Our approach during hot weather is to close the house down. Blinds and curtains closed as well as doors and windows. When we get up it’s opened up to let cooler air in, then the same in the evenings. Also at night the loft opening is raised to allow warmer air to exit the landing where the hot water tank is located.In my opinion, all new houses renovations or extensions should be built to much higher insulation standards. In theory it is possible to so well insulate a property that the people inside are enough to to keep it too warm for comfort. There are some difficulties achieving that level of performance because you need to have some air exchange to allow them to breath, but with effective heat exchangers it is possible to minimise heat losses through ventilation.
The other problem that chris the caravanner has alluded to is too much heat gain and retention. We need to take some lessons from Arabic house design where in hot conditions the house can create a strong natural convection circulation to allow over heated air out.
We took the hint from France and Spain. We now do the same as above and it works for us like during this past summer. Why open windows to let hot air in?Our approach during hot weather is to close the house down. Blinds and curtains closed as well as doors and windows. When we get up it’s opened up to let cooler air in, then the same in the evenings. Also at night the loft opening is raised to allow warmer air to exit the landing where the hot water tank is located.
We too have a couple of small gas camping stoves which are available for emergency use should power be out for a longer period. Plus led chargeable lamps with 8 hours output when on low and several torches too. Fortunately not had to use any of the backup kit for many years.We took the hint from France and Spain. We now do the same as above and it works for us like during this past summer. Why open windows to let hot air in?
As for the winter we have always had a small gas camping stove and two Campinggaz lamps. If it gets too cool, we have the gas heater as a backup and we run for about 20 minutes at a time just to bring up the heat again. We would never run the gas heater continuously.
But why is it "ridiculously expensive" designing to include good insulation shouldn't be expensive, and the insulation its self is not massively expensive either, It really shouldn't be prohibitively expensive to build far better insulated homes.To design and build an efficient house that was green and promoted healthy living is fairly easy. but ridiculously expensive. The solutions are to find the right compromise.
I spent sometime in northern BC Canada, and observed several new properties being built, their costs were not excessive, yet they were far better insulated than here in the UK. I dont think its material costs that are the problem, it's the building companies that don't want to change embedded practices. It needs legislation and regulations to change to drive the process. And as you say it needs those who monitor the planning and building control to up their game to enforce the performance of builders.
