- Feb 27, 2010
- 633
- 0
- 0
Relative to the caravan itself it does not move, relative to the centreline of the towcar of course it does when the caravan goes into a snake.
Lutz, the Centre of Mass cannot change ( unless you have founded a new branch of physics ) unless the contents of the van move position, it is fixed . It can not move. Tbe cnetre of mass is not a dynamic entity.
The snake . please , try to understand the actual mechanics of a snake .
How does the ATC work ?. ok . in snake the caravan starts an uncontrolled snake , which is actually a yaw. This develops into a harmonised yaw that becomes an oscillation. This applies a load to the rear of the towing vehicle and as we all knoNewtons 3rd law - dont we- the towing vehicle has to react in the opposite deitection.
Due to the nose of the towin gvehicle now moving away for the front of the caravan the driver tries to correct, but this movement will start to increase the amplitude and frequency of the oscillation because the driver can not correct fast enough.
Viewed from above the towed vehicles wheels actually describe a series of arcs , and it is this motion that needs to be controlled. The outside wheel of the arc has to accelerate , it cant do anything else, ( thats physics again then the van rolls back and past the centre of swing , which means this wheel now starts to decelerate and the other slower wheel starts to accelerate and the same starts to occure to the rear of the towing vehicle.
The braking system on the van sarts to apply the brake to the accelerating wheel there by slowing it and in doing so reduces the size of the described arc made by the wheel. Then as the swings back to centre then the brake is released and the opposite brake is applied,. This action satrt to dampen the yaw.
On towing vehicles the same system works , call it ESP , TCP , whatever you want, but thats how it works.
Also , a large , high 4 x 4 is the worst vehicle to be in when a large uncontolled yaw starts, simply becuse arge 4 x 4 have a very high c of m, soft anti roll bars , large sidewalls on the tyres and a long suspension travel. Its 4 x 4's that usually flip. Thats a fact as well.
A little knowledge eh ?
Now then , where is the ignore button?
