Some advice please
Aug 30, 2024
Hi new to caravaning, I bought a Bailey Pageant Auvergne series 5 back in June and we have been out in it half a dozen times and love it.
It had a broken nearside rear light cluster, purchased a replacement with reversing light and when fitting it I found an extra wire yellow with black strip which I thought was the reverse light connection but it appears to have no power. When I checked under the consumer unit for where the grey cable comes in the yellow wire for the reversing light was cut short and not attached to anything. Does anybody know what this yellow wire with black strip was for or where it comes from. (Just for information the yellow wire with black strip is also behind the offside light cluster)
Mar 3, 2022
406
321
4,935
Apologies.
Can't help with your problem. Can only suggest you find a good mobile caravan engineer in your area.
Reactions: Hoey
4,547
Yet again without being there with a multi meter, it is hard to diagnos the problem.
Good luck , maybe someone with the same van can help.
