Hi, I would like to put a splashback at the side of my cooker, it is to fit on the outside of wardrobe, any ideas where I could get one. Thanks for any help
I am struggling to understand why metal would heat up so much that it burns the wood if the wardrobe wood can take the heat without the metal in the first place?elddis do one which is perfect for a cooker, done in brown smoked heat resistant glass about 6 inches high, check s/hand vans at dealerships to find model
dont use metal it will heat up too much and burn the wood behind!
if a cooker has been fitted next to a wardrobe from new,then it should have a splashback fitted, the correct glass ones have small spacers on the back and the glass does not touch the wood and it is heat resistant, The wood would stand a bit of heat from the cooker but I have seen the wood veneer bubble when the incorrect size pans are usedI am struggling to understand why metal would heat up so much that it burns the wood if the wardrobe wood can take the heat without the metal in the first place?
