Split black tape(?) round window
Apr 25, 2016
19
Just noticed that the black tape(?) on either side of the front roof window on my Conqueror has split and needs replacing. No sign of damp inside so probably the tape is just for show. What do I use for a replacement?
Thanks for your help.
1,793
Not sure what you refer to as tape or the window you are referring to. Is this the rubber surround and the window the one immediately over the front three or a skylight?
Apr 25, 2016
19
Thanks for replying.
It's the window on the sloping front part of the roof. There's a black tape running down both sides..
34
10,685
I assume you are referring to the black stickers/graffics that surround the windows? If so you've got a couple of options,go to a swift dealer or look online for decal kits(best bet) or go to a local graffix place that stickers up tradesman vans etc...and see if they'll do you some copies.If non of the above,sorry can't help until I see a photo :)
333
There has been a similar problem reported on Swift talk with photos ,it seems the tape splits due to age and weather, I think Swift changed it on later models, i can't see any tape on ours, so think it was a change of front window/roof window design.
