Steadie blocks
5,470
Sadly we probably cannot use our caravan until Easter next year so will not be able to try out the block until then. We do know of people that have been using them for a while with no issues. We mainly need them for our centre jacks.
2,652
We will not be using our caravan until 21st April so i wait until someone trys them and with no issues .
4,157
1,887
Do others not store their vans with steadies, or axle jacks deployed, so needing some load spreading blocks even now?
5,470
When using CLs etc it is not uncommon to come across uneven pitches. We would not bother with the blocks in the storage yard.
9,483
Yes mine has its steady feet fitted with pads and they go on square plywood blocks.
Reactions: JTQ
2,652
The steadies feet on mine have pads and they go on blocks of wood in the caravan storage
4,751
We only use blocks, if the steady legs are not"steadying" we have pads on the legs, why use blocks as well?
2,652
My caravan is in storage and although the ground is firm it is very stoney indeed mainly for drainage purpose, we have pads on the legs and use the wooded blocks underneath the legs now feel sturdy so in view of this if the caravan feet are not flat then they are unstable to which the van is likely to move in slightly windy conditions and also when occasionally visit and enter the van. this is my prefered choice
4,157
1,887
My "blocks" serve as pads, one thing doing both functions, all part of trying to declutter the hobby.
Looks a potential weakness in the foam blocks, they need the load spreading so dictate using pads, whereas the wooded blocks certainly don't?
5,470
Maybe instead of referring to them as "Steadie blocks", they should be called "Levelling aids!.
5,470
The blocks were delivered earlier in the week and I have now fitted them on the nearside of the caravan so that the caravan is tilted towards the offside for water to drain off. Also wheels no longer have so much pressure on them.
2,652
i think that a good idea for the wheels to remove the pressure on them my breathable cover takes care of the water .
Reactions: DaveA1
