Swift Challenger Locking Door
Aug 5, 2023
629
261
2,135
Since we purchased our first caravan in 2023 both of us have always thought it was normal to slam the door so the handle could be moved up to the lock position when going to bed or simply locking it for security.
Wasn’t until tonight we thought, surely this can’t be right….having to slam the door when people could be sleeping doesn’t seem right.
Adding to the fact having other Swift people around us, we’ve never heard a slam from anyone else.
Anyone else have a Swift and have to really pull, slam the door so the handle can be locked, may just be misaligned.
Could be wrong but just want to check with everyone before sending off an email to our dealer :)
4,486
Not on the Swift,but our Coachman states pull handle , before closing from the outside. But inside just pull to close then turn to lock.
Reactions: Slowtow
Aug 5, 2023
629
261
2,135
But you don’t need to slam the door mate?
I’ll try the ‘pull’ method tomorrow and see if that works
552
327
19,135
Our Swift is also 2023 ,and no need to slam door. Or our previous Swift bought new in 2013. Just gently shut door and locking easy no effort whatsoever required.
5,219
Try the butcher in Brampton, Gloves GW and sons
Bought a half lamb, all boxed up fitted in the bottom of caravan fridge just nice.
Hutton le Hole, great CL site, wonderful pub and a fantastic chocolate factory.
Slamming doors and butchers🙃🙀
Aug 5, 2023
629
261
2,135
This was rather off topic mate? 🤔😂
629
261
2,135
Thanks all,
I’m going to also visit a dealership and try a few swifts
Then I’ll fire off the email to my dealer
4,266
No you shouldn't need to slam the door for it to close and latch properly.
If you haven't already, may I suggest you watch all the video's posted by
Beyond the Brochure: Caravan Reality
This gentleman has recently bought a swift caravan, and has had a catalogue of failures, some of which he has repaired himself but most would warranty if it had been convenient to get to the dealer.
His experience is far from unique, and it makes me suspect most problems with Swifts are down to a combination of poor design, and poor workman ship - both of which are prime examples of a failed or non existent Quality Management System.
The saddest thing is the caravan buying public have become so used to having such issues, that most new owners actually expect to find problems. and worse, the caravan industry know they have an abysmal quality record, so they actually build into the cost of a new van a surcharge to cover the averaged cost of warranty repairs!
Caravan satisfaction Surveys carried out over several years have consistently shown that about 20% of new caravans (Across all brands) need substantive warranty work. That is an abysmal statistic, and it ignores all the lesser problems that owners fix themselves, things as trivial as sawdust in draws, the odd screw rolling around, to cupboard door being warped or a door lock not working, all of these are indications the manufacturer has not completed the assembly job correctly and which affect the end user to some extent. I'd bet that 90% or more of new caravans exhibit some manufacturing or assembly failures if we accept that uncleared sawdust is a manufacturing failure.
They are actually charging us to allow them to make mistakes! If they were to put their house into order they could actually reduce the retail price of all caravans by over £1000 each, and still make the same profit but more impressively on a smaller turnover, They would also have a happier customer base, more likely to both recommend products to friends, and generating return business.
According to the consumer rights act, customers of brand new products should expect them to be fault free!
Sorry for the rant.
2,188
Have you looked at the inside door plate that the catch engages to. Most of them are on the wrong way around with the recessed bit facing the opposite way to the tongue of the catch! Can’t see clearly on your video but think yours might be. Need my better glasses! Easy to turn around. Even we managed it.
Reactions: IanB1485
Aug 5, 2023
629
261
2,135
Will definitely look at this when we get back, hopefully an easy fix..
I’ll also take a photo closer up and post
Thank you
Reactions: Mel
Aug 5, 2023
629
261
2,135
Hi Mel, here are the photos, hope this helps
May 30, 2024
95
109
635
Thanks. The black plate between the two small screws is the wrong way around. Take it off and turn it so that the recess is on the side of the door opening.
Interesting! I shall look at my striking plate now as well, since I've always felt that it took a firmer pull than appropriate.
I guess the alternate argument would be, that the door does need to attempt to seal against water ingress, so the rubber seal does need to be compressed when the door is latched.
Maybe you've noticed, Saxo, but those are Torx head screws. End of a teaspoon won't be good enough.
8,925
Let’s hope the same operative isn’t doing wiring and gas connections🙀
Wouldn’t you have thought someone in the dealership might have noticed it as they were going in and out readying the caravan and doing PDI. Say no more M’lud.
