thedoog1 said:
Hi, when i have aligned the arial with my signal finder to get the best signal,and then tuned the television in. If the tele gets moved at all i lose the settings. Is this normal or a fault with the television.
Steve
Not quite sure what you mean by 'moved?' Do you mean disconnected and moved within the caravan to a different position, or you move the caravan to a different site?
If the former, if you are using a different aerial socket is that socket being fed with a signal from the aerial? Some caravan manufacturers fit two or more sockets but only connect one of them to the aerial amp, the other port on the aerial amp often being used to feed the car radio. The cable(s) from the unused socket(s) will be presented next to the aerial amp and may need to be swapped over.
If there are two or more cables and the amp has enough outputs to feed them all then it suggests your TV is not remembering the stations it has found with an auto-tune. Some TVs do the channel scan and then ask if you want to save the stations it has found. If you don't take that option it may allow you to continue using them but when you remove the power it will forget them and revert to the last set of channels that it 'knew.'
The other possibility is that your TV has not been retuned. In the olden analogue days a TV transmitter used one frequency to carry one TV station; now with digital 'multiplexing' (known as a mux) each TV transmitter uses one frequency to carry one mux but that one mux may carry 6-8 TV stations and a handful of radio as well.
There are three types of TV transmitter sites known colloquially as Freeview Lite, full Freeview, and Extended Freeview. All stations use Freeview Lite which has three transmitters that are:-
PSB1 formerly known as BBCA which is all BBC TV and radio;
PSB2 formerly known as D3/4 which is the main ITV stations including Ch 4 and five;
PSB3 formerly known as BBCB which carries the primary HD stations.
PSB is Public Service Broadcasting: HD is High Definition which needs the TV to have a Freeview HD tuner.
Full Freeview stations are generally main station transmitters of which there are 80 odd, or former relay stations that have been upgraded to primary stations in their own right - such as Sheffield, Chesterfield, Scarborough and quite a lot of others. Main stations transmit PSB1-3 as the Lite stations plus:
Com4 also known as SDL which transmits some of the other major stations such as Sky News etc
Com5 also known as Arqiva A which transmits many of the smaller stations
Com6 also known as Arqiva B which is functionally the same as Com 5
The Extended Freeview stations which are a handful of but not all main stations also transmit:
Com7 which transmits the balance of the HD stations
Com8 which transmits some other stations in both standard and high definition.
Com7 and 8, like PSB3, require a Freeview HD tuner
For the record standard definition is also known as DVB-T (Digital Video Broadcasting - Terrestrial) and DVB-T2 which is version 2 is used for HD transmissions. A DVB-T2 receiver will also decode DVB-T transmissions but not vice versa. It is likely that within a few years all terrestrial transmissions, SD or HD, will be using DVB-T2 as it is much more efficient in its use of spectrum and is also much more resilient under poor signal or interference conditions. It has been the law for nearly two years that all TV's sold in the UK of 32" or greater screen size be fitted with a Freeview HD tuner although not necessarily a screen capable of showing full HD (a.k.a. 1080p.)
The issue is that when your TV changes transmitters because the caravan has moved then it needs to be retuned. The only way that this can be done reliably is if the TV is set to factory default (i.e. out-of-box) conditions: there is usually an option for this somewhere in the menu system. It is also thereafter preferable to manually tune the TV rather than let it do it automatically for two reasons:
If the TV has been previously tuned and is then set to auto-tune again it sometimes does not do a full retune but just checks for updates. This would mean that any 'new' stations will be regarded by the TV as duplicates and be positioned at channel 800 and above.
TVs always start tuning at TV transmitter channel 21 and tune up to channel 68 (even though nothing above channel 59 is now used and likely above channel 49 in a few years time as the frequencies are sold off for mobile phone use.) This means that if the transmitter site you want to receive has high channel numbers but there is a nearer transmitter that you don't want to receive you may end up with the 'wrong' one. Manual tuning will ensure you get what you want.
To find out go to
www.wolfbane.com and insert either the postcode or the map reference of where you are going, select DX, and set the aerial height to 4m, and it will show you which transmitter sites cover that location. Any station showing a signal strength above about 45 or so should work although the highest should be the one used if possible - ignore the comment about the type of aerial needed, the site is notoriously pessimistic. Write down the channel numbers, direction, and polarity for the transmitter site or sites you may want to use. Then when you get to your camping site set the TV into manual tune mode and use those channel numbers, having pointed your aerial in the right direction first of course.
