Feb 21, 2025
6
12
I purchased a new caravan in May 2024 and since we've had it the Thetford toilet flush pressure seems to be excessive such that flush fluid collects/pools under the toilet seat/lid, then pools and dribbles down outside the toilet and onto the floor area if not checked/wiped after each use. Has anyone had similar issues and if so how were they resolved?
Apr 23, 2024
459
381
935
never come across that (in ours it's a manual flush and over enthusiasm can result in the same). buy a cheaper lower rate pump , or drill a hole ( 1mm) in the supply pipe, both of these will require opening up the flush tanks, conversely just press it for shorter amount of time
Sep 4, 2011
588
360
19,135
Previous caravans when new had an Orange insert inside the information wallet which pushed inside the end of the pipe in toilet bowl to prevent water splashing over if to much pressure. This had a smaller hole in it to reduce the flow
Feb 21, 2025
6
12
Thank you all for your quick replies. I spoke to our caravan dealer who also mentioned the orange flow restrictor so I'll look through our pack and fit if I find it. Our dealer will also fit if not found when our annual service is performed in May. Many thanks again.
Reactions: Mel
Feb 21, 2025
6
12
Just an update. I fitted the flow restrictor and found that it went from one extreme to the other. There was so little flow that the flush fluid was not getting more than half way around the toilet bowl. I removed the restrictor, drilled it out a little which was easy given that it's plastic, refitted it and have found a happy medium. The fluid swirls around the whole bowl now but doesn't wash over the top or dribble down the back of the toilet.
Apr 23, 2024
459
381
935
Interesting , I have a manual flush and have to careful not to pump too hard as the same thing keeps happening
