Thetford Fride Issue
Mar 25, 2024
Hi All,
My Thetford fridge has an issue with the read control board.
It often turns off and I have to go outside, remove the vent from behind it and wiggle the board until I hear it click, then the fridge powers on. Sometimes it goes off and I have to go back out and move it into a different position.
I believe it may have something to do with the levelling sensor (if that’s even a thing). Even when on level ground I have to move the board so it’s on an angle.
Any suggestions on what the problem could be and if there is a fix for this?
Replacement boards seem to be out of stock or costing over £1000 so a new fridge would be cheaper, ideally I’d like to fix it. I’m pretty handy with electrics.
I have attached a pic of the manual for the model number.
Jun 6, 2006
705
83
18,935
A replacement PCB is generally about £100 and not £1000.
Not on the older Thetford fridges as they stopped producing the PCB 18 months 2 years ago, if someone has the PCB they ask what they want for them. And for reference the Thetford PCB was around £140-£150 ish when they were readily available
3,594
A few years ago there was a small business that repaired PCBs based in Cirencester. I wonder if any such companies exist today? Anyone asked Apuljack?
Reactions: nickslane
3,467
32,935
There is a place that refurbishes them and hopefully someone will remember the name?
Mar 25, 2024
I will have to see if I can find someone that fixes them.
There are out PCB out there that look identical but have a different partno, not sure if it would be worth the risk buying it to see. They are around 220 Euros.
