Thetford Fride Issue
Mar 25, 2024
Hi All,
My Thetford fridge has an issue with the read control board.
It often turns off and I have to go outside, remove the vent from behind it and wiggle the board until I hear it click, then the fridge powers on. Sometimes it goes off and I have to go back out and move it into a different position.
I believe it may have something to do with the levelling sensor (if that’s even a thing). Even when on level ground I have to move the board so it’s on an angle.
Any suggestions on what the problem could be and if there is a fix for this?
Replacement boards seem to be out of stock or costing over £1000 so a new fridge would be cheaper, ideally I’d like to fix it. I’m pretty handy with electrics.
I have attached a pic of the manual for the model number.
Jun 6, 2006
1,040
260
A replacement PCB is generally about £100 and not £1000.
Not on the older Thetford fridges as they stopped producing the PCB 18 months 2 years ago, if someone has the PCB they ask what they want for them. And for reference the Thetford PCB was around £140-£150 ish when they were readily available
5,587
A few years ago there was a small business that repaired PCBs based in Cirencester. I wonder if any such companies exist today? Anyone asked Apuljack?
Reactions: nickslane
5,505
There is a place that refurbishes them and hopefully someone will remember the name?
Jun 6, 2006
1,040
260
Apuljack hadn’t anything planned several months ago, but knowing Paul he will reverse engineer one
I will have to see if I can find someone that fixes them.
There are out PCB out there that look identical but have a different partno, not sure if it would be worth the risk buying it to see. They are around 220 Euros.
