My wife is trying to convince me that we should consider fully serviced pitches. I don't have a problem getting and emptying the water but she's not exactly conservative with the water use and she's trying to be kind to me.
I have some insight into what we'd need but there are different options.
For incoming water I've seen both a direct connection from tap to van by Whale or via the Aquaroll and a float valve. What do you think?
Also what's a reasonable length for the water supply pipe?
On the waste front I'm not that keen on the corrugated waste pipes... they collect gunk and also can sag and won't drain well. I'm considering some rigid pipe following some suggestions I saw on the Caravan Chronicles.
Any suggestions welcome
