- Jan 3, 2012
- 11,220
- 2,649
- 40,935
I think it a Metric adjustable but only one at present🙏Is the spanner Metric or Imperial. ?
Does it matter if it's metric or imperial - as it's adjustable.I think it a Metric adjustable but only one at present🙏
So the nut using the metric adjustable spanner can only use it on an adjustable nut? 🤣 🤣 🤣I'd only use an adjustable spanner if it was used on an adjustable nut
If a hammer doesn't fix it, it's electrical!An adjustable 10lb hammer, you can just a lot of things with one 🤔🤣
This is a good pointIf a hammer doesn't fix it, it's electrical!
I recently got this from Screwfix Magnusson carbon steel sledge hammer 10lb you can do a lot of damage with this.🙏An adjustable 10lb hammer, you can just a lot of things with one 🤔🤣
Admire your optimism. 😂I also had the thought this morning in the last 20 years of owning a car I've never needed a tool to fix anything.
I'm hoping the same applies for the van however I will take a few just in case
To be fair we have decided we will only do hard standing and well resourced sites. So genuinely what's the worst that could happen?Admire your optimism. 😂
Thats an almost impossible question to answer as its very much owner and location dependent.To be fair we have decided we will only do hard standing and well resourced sites. So genuinely what's the worst that could happen?
Anything remotely serious or detrimental to us being in the van we just got home
It can be like a Pandoras box, a couple of loose screws on a door, you tighted up three and strip the last one, get the wooden toothpicks out the fill the stripped hole, then you start checking doors, Oh the light in the wardrobe isn't coming on, change the bulb, notice the aerial wires are slack to the amplifier, Then the wardrobe door doesn't work. Fixing that the bar across the wardrobe is loose.I also had the thought this morning in the last 20 years of owning a car I've never needed a tool to fix anything.
Wise decision! But which few?I also had the thought this morning in the last 20 years of owning a car I've never needed a tool to fix anything.
So true, also to what extent will you repair. I carry sockets up to 14 mm, spanners upto 22mm allen keys and torque drives up to 14 mm. Single Adjustable wrench , metric one side, Imperial re other, and a single left/right handed screwdriver. Multi meter( with new battery's) spare fuses, soldering iron, and solder, ( made that mistake one, NO solder) and a torque wrench.Wise decision! But which few?
What no zip ties🙈So true, also to what extent will you repair. I carry sockets up to 14 mm, spanners upto 22mm allen keys and torque drives up to 14 mm. Single Adjustable wrench , metric one side, Imperial re other, and a single left/right handed screwdriver. Multi meter( with new battery's) spare fuses, soldering iron, and solder, ( made that mistake one, NO solder) and a torque wrench.
String and Nylon cord. Duct tape, Alloy tape.
Car now probably over weight.
No they are in the car boot with the torque wrench, crowbar, tow rope battery leads, tyre inflator, rescues spade, first aid kit, inflatable limb splints, and space blankets. And 2 lb hammer.What no zip ties🙈
Let me know your next pitch numberSo true, also to what extent will you repair. I carry sockets up to 14 mm, spanners upto 22mm allen keys and torque drives up to 14 mm. Single Adjustable wrench , metric one side, Imperial re other, and a single left/right handed screwdriver. Multi meter( with new battery's) spare fuses, soldering iron, and solder, ( made that mistake one, NO solder) and a torque wrench.
Anseo, done that before I finished pitching up. At ingleton.Let me know your next pitch number
I'll park next to you. Saves carrying all my tools 😉
