towbars
Stuart,
With certain exceptions, the car manufacturer will source the tow-bar from one of the specialist manufacturers: Names that come to mind include; Bosal, Westfalia, Brink, Witter, and others.
Then companies like Towsure and EECO in the UK who produce tow-bars for after-market fitting.
Now that type approval applying to tow-bars, they should all be dimensionally identical and built to a certain standard. What sets each tow-bar manufacturer apart is the items not covered by the TA process: Specifically the quality of the steel used, the quality and checking of the welding and fabrication, and the surface coating / rust prevention.
Unfortunately much of this information is unavailable to people outside the industry, but Bosal and Westfalia will probably feature on most German designed cars (and Opel / Vauxhall)
The other part of the tow-bar is the electrical wiring package, and you need to find this out too: A dedicated harness costs more, but simply plugs into an existing socket; a relay isolation kit is cheaper but takes hours to install - taking the signals from the existing wiring and drawing power from a separate circuit; and then there are the scotchlock cowboys.
Summary:
The Vauxhall (Opel) tow-bar won't be a Towsure model, but I know what you mean - if you'd picked a different combination you could have bought the self same Bosal tow-bar and paid two very different prices.
In your case, the car manufacturer should have exercised some diligence in making sure that the tow-bar they offer has the best corrosion and build qualities, but then again, if it's a dealer fit item - they may just get a local fitter to do the job - and then you could easily end up with a Towsure, EECO, or other tow-bar.
We've always bought detachable tow-bars that I know are used as OEM products from the manufacturers - Bosal, Brink or Westfalia - and have them fitted by a specialist independent fitter who I know is used by the local MB dealership.
Robert
With EU standards, all towbars meet the necessary spec. I would be guided by cosmetics ie bumber cuts etc.
I chose a Witter for my Land Cruiser because the Toyota supplied one makes it necessary to make 3 ugly cuts in the rear bumper.
Brum
Hi stu, these bigger company,s or manufacters make money big time, something simerly happened to me some time back, i got a quote from tow sure for a tow bar, then got a quote from my local small car part shop, now this small shop buy in bulk so inturn sell cheaper in my case, the price from towsure was more expensive than my local car shop, and yet the car shop bought the tow bar,s from tow sure,
Now towsure is a top store dont get me wrong, but it may be worth shopping around, and get price,s it will open your eyes to the varous prices and how much you can save.
Better still try a local car parts shop who just might get your towbar a lot cheaper for you.
Good luck john.....
