Just sold our single axle and ordered a twin. There doesn't seem to have been any recent postings regarding differences in towing procedures so can fellow "forumites" tell me if there are any differences? Should I be aware of any potential problems?
Self leveling suspension in my case, Never had any noseweight nor leveling problems nor been refused entry, wouldnt be without my TA love it.Surfer said:One issue to consider is that if the towing vehicle is loaded at the rear the hitch will be lower anyway so sort of makes a mockery of noseweight as physics dictate that the lower the hitch on the towing vehicle the "lower" the noseweight on the caravan will be at the connection point.
Not sure how to get around this one?
The relation of hitch height to its imposed load only holds 100% true for single axle caravans. In twin axle units the imposed nose load can change dramitcally over small height difference, but depending on how the caravan is loaded under a range of circumstances the hitch load can actually stat to lift rather than sink. Its all to do with where the CofG sits inrelation to the two axle lines, and the interaction of the suspension on each axle.Surfer said:All your points above are valid, but not sure on the noseweight issue. Our noseweight can be between 80 and 100kg and it makes very little difference, however we do try and keep it to around 95kg.
You might have a long overhang at the rear of the caravan so you need to be aware when negotiating tight turns into and out of site entrances.PaulT said:Just sold our single axle and ordered a twin. There doesn't seem to have been any recent postings regarding differences in towing procedures so can fellow "forumites" tell me if there are any differences? Should I be aware of any potential problems?
Prof John L said:The relation of hitch height to its imposed load only holds 100% true for single axle caravans. In twin axle units the imposed nose load can change dramitcally over small height difference, but depending on how the caravan is loaded under a range of circumstances the hitch load can actually stat to lift rather than sink. Its all to do with where the CofG sits inrelation to the two axle lines, and the interaction of the suspension on each axle.Surfer said:All your points above are valid, but not sure on the noseweight issue. Our noseweight can be between 80 and 100kg and it makes very little difference, however we do try and keep it to around 95kg.
On a TA if you let your hitch drop and it refuses to fall to the ground, at the height it stops it exerts no hitch load either up or down. Insome TA's I have seen the distance the hitch falls from its towed height can be as little as 75mm. That was 75Kg to 0Kg. That is a significant change over a relativly small distance, which is why I maintain it is so important to measuere nose weight correctly.
certanty of your statement only holds true foro single axle units
