Truma 3002 heater in Bailey Senator
Jan 7, 2006
75
Hi everyone - we enjoyed our first weekend out in new Oklahoma a couple of weeks ago. We wanted to keep the heat on low using electric during the night as it was quite cold but I woke up in the early hours to find that the caravan was cold.
We tried different settings and variations during our stay but it was either too warm or too cold during the night.
Any advice would be welcome on how to set the heat to stay on a low temperature all night to take the chill out of the air.
Thanks for your help
Janet
Aug 4, 2005
1,204
14
19,185
We have the Indiana, Bailey's handbook recommend the heater as being most efficient when using gas rather than electric and we have found that to be the case. Were you using the blown air system or just the space heater by itself?
Robert
Jan 7, 2006
75
Hi Robert
We tried both, probably the blown air system more so. Got the heating working fine during the day although the blown air seems to be very hot in toilet area & less warm at front seats.
Are there any particular settings you use to generate a low heat suitable for during the night which will not cause the caravan to become too warm?
Thanks for your reply
Janet
Aug 4, 2005
1,204
14
19,185
Hi Janet,
Know what you mean about the toilet becoming warm with blown air system,it can get like a sauna. Try altering the vent opening to reduce the flow of warm air into the toilet.
When we have used the heating overnight we have tended to use it on electricity and as a space heater only without the blown air. If I remember correctly the thermostat settings go from 1 up to 8, we set it around the midway mark.
One weekend last year when it was particularly cold we used it on gas with the blown air system,that seemed to work for us on mid setting on gas and fan.
Robert
Nov 1, 2005
1,001
I have a feeling that the electric element won't be particularly powerful and as such the warm-air fan will be cooling the element so that you'll only be circulating cool air. Try using the heater with the blown-air turned off.
Aug 4, 2005
1,204
14
19,185
Yes, I think you are right Mcghee, I can't check tonight as the hand book is out in the van, but I'm sure the recommendation is only to run the blown air when using gas. I'm also fairly sure it only recommends the electric as a means to boost the gas for a short period until you achieve the desired temperature.
The only reason we used the electric system overnight was because of a reluctance of someone in the van to sleep when the gas was on!
Robert
936
Janet, it could be that problem is in the siting of the room thermostat, it is a well known problem.
If your control/thermostat switch is located anywhere near the fire,it is probably sensing the temperature in a confined space, like behind a panel which is close to the fire.
The problem is, the van warms up, including the space the sensor is in, which may make the van uncomfortably hot as it reaches the set temp.
Th ethermostat then cuts in, switching the fire off, and the van cools down, but the space where the sensor is, cools a lot slower than the body of the van, you then get cold awaiting the thermostat to cut back in.
The answer is to fit a remote sensor low down. The operation is still by the normal switch, but the sensor built in to the switch is overriden by the remote.
If its a new van, report it as a fault and get it altered under warranty.
You should be able to use blown air whilst using electric without any problems, and if you do not, then remember the front of the fire will get very hot!!
Setting it on 500w should be enough to keep the chill off overnight.
Jun 6, 2006
705
83
18,935
Janet
6 Apr 2007 07:29 PM Hi Robert
Janet
Rob-T
6 Apr 2007 09:52 PM Hi Janet,
Robert
You can change the air flow on the back of the Truma heaters by moving the vent on the back of the heater, it should tell you in the hand book how to do this. On our van I have to take the draws out in the kitchen area to gain access to the back of the heater then find the sliding/rotating damper on the pipe system.
Jun 6, 2006
705
83
18,935
Janet
Janet
Rob-T
Robert
You can change the air flow on the back of the Truma heaters by moving the vent on the back of the heater, it should tell you in the hand book how to do this. On our van I have to take the draws out in the kitchen area to gain access to the back of the heater then find the sliding/rotating damper on the pipe system, this will put more air to either the front or back of the van depending on how it is set.
Martin "E"
Sorry missed out the last bit on my last post
Aug 4, 2005
1,204
14
19,185
Martin,
Thanks, I knew that the air flow could be altered by moving the vents at the back of the heater. I'm not too familiar with the layout of Janet's Oklahoma but with the Indiana there are two air outlets to the rear of the van. Altering the vent would decrease the air to them both but it is only the one in the small enclosed space of the toilet compartment which really needs cut down. I found that if you just alter the swivel cover on the outlet it cuts the flow enough to make a difference.
Robert
Jan 7, 2006
75
Hi everyone - thanks for all your replys.
We are heading off in van today for a week so will have plenty of time to try out all your findings.
Same as yourself Robert with regards to keeping the gas on all night - we tried this first time but the flame blew out due to it being quite a windy night. We then reverted back to electric as I was a bit nervous about using the gas again when sleeping.
Anyhow, thanks again everyon and enjoy the Easter hols.
Janet
3,142
Hello Janet,
The Truma 3000 series heaters and the similarly spec'd Carver models are generally very reliable in most wind conditions. It must have been either an exceptionally severe wind, or some other circumstance that caused the flame to extinguish.
In either case you really do not have anything to worry about as both types of heaters have flame failure gas cut of valves, which does exactly as the title suggests. If the flame goes out, within a few seconds the gas valve will automatically close.
Also the heaters are what are called room sealed. This simply means that there is no route for the flue products to leave the heater and enter the caravan. This is a proven system and used throughout the world.
It is really a matter of personal choice whether to use the gas heater overnight, or not, but unless the heater has been incorrectly installed or damaged, then there really is nothing to be worried about.
We have the Oklahoma and find that we can get it "right" for electric heating overnight by selecting 500/1000/2000 on the control knob depending on the outside temp,The centre of the knob controls the temp maintained by the thermostat.
I have moved the thermostat/switch to be accessible when seated on the door side and this has moved it away from the heat of the cupboard side above the heater.The remote sensor is underneath the wash basin at floor level.
The lever on the back of the fire just diverts the air flow fore and aft.
I have put an extra outlet in the ducted air so that it warms the area by the door .This is Teed into the pipe to the back/toilet so the hottest air is going to the living area .
Bailey (it seems to me ) have rationalised production on the Indiana and the Oklahoma.The Indiana heater is further towards the back of the van and the piping to the front of the Oklahoma goes backwards a couple of feet before doubling back on itself to go forward !!
There is also a big build up of heat under the drawers behind the heater and the back of the thermostat/switch and fire switch get very hot and this will affect output.
I have fitted a 6in X 4in approx vent below the switches and also replaced the small one in the front above the fire with 2 vents of the same size.
The wasted heat now comes into the body of the van.
Finally the gas operation is about 3 Kw and it is recommended for initial faster warm up but the electric at 2Kw should be more than adequate to maintain the temp if its working/ being set right.
Hope that helps
Jan 7, 2006
75
Just back from our Easter week away and used the heater on the gas setting 1 or 2 during the middle of night. This seemed to work great at keeping the van at a nice temperature for sleeping. I think previously we had tried to use the blow heaters on electric and it just didn't work - kept blowing out cold air!
Thanks John L for your comments - that gives me peace of mind using the gas now.
Will try the electric settings as you say Watson(John G) - when you say the electric at 2kw should be adequate do you mean selecting the 2000 on the control knob? Reason for asking is our dealer, at one time, had mentioned keeping this at 1000 to avoid tripping the electric. Because of this we have never used the 2000 setting.
Janet
Hi Janet the lever at the back is to divert flow between front and rear.
The dealer is right in saying use 1000 on a busy site as the site electric supply may not cope if everyone does it at the same time nad boils the kettle etc.
I practice I have never found this to happen but we don't go away in the depths of winter.
Last time we were away during the week the site was 1/2 empty and at 16amp would cope with the heater on 2000 but at the weekend when it was full we used the gas as well
Hope that helped
Hope that helped
The lever is easy to access and the dealer would be referring to the site electrics not the van
Will get hubby to have a go at changing the lever at back of fire to divert air flow.
Thanks for your help.
Janet
Just pull out the 2 drawers and put your head/hubbies in the void under the microwave.
It doesn't make a big difference but every little helps and you can also shut down the rear vents of course.
Apr 17, 2007
86
We have tried all electric settings and find the heating very dissappointing. We winter caravan in northern scotland have to use an alternative electric heater. The Carver Fanmaster was a far superior heater but they were taken over by Truma and their heater was deleted.
John sorry your heater is unsatisfactory
Ours is every bit as good as Fanmasters we have had in the past
I wonder if you need the remote temp sensor.
We had one fitted to the Ace(it just plugs in) and that was a big improvement
Previously we had to adjust the thermostat knob every time to raise/lower the temp but with the remote sensor it worked OK
Apr 17, 2007
86
We are now on our 3rd caravan with the Truma heater.We have had temp censors in the last two. Remember it gets very cold up here.
chenzhen
BANNED
May 19, 2016
99
"The word vintage, used to describe dresses and clothing, is a broad term that is generally used to refer to clothing that originates from a past era. In general, clothing that dates earlier than the 1920s, is considered to be antique. Whereas clothing and dresses that have emerged after the 1920s, up to the 1980s and 90s, is considered to be vintage. Retro, or vintage style, usually refers to clothing that is an imitation of the style of a previous era.
A range of vintage style clothing that is hugely popular today, are the fifties dresses. The enduring popularity of these dresses, might be because that was the time women's clothing made significant strides, as it was after the second World War and many restrictions had been lifted and designers had more freedom and materials available to create beautiful women's fashion ranges.
Some of the popular dress styles that have enjoyed a timeless appeal have included the Ophelia dress, floral tea dresses, Audrey Hepburn style dresses, the figure hugging Lindy Bop dresses and dresses made famous by Grace Kelly and many classic Hollywood stars. Even today, young women are choosing vintage style dresses for their special occasions such as a ball, prom night, and other formal parties, because they have a definite charm and elegance and have been designed to enhance a woman's shape and beauty."
fake oakleys
michael kors uk
cheap ray bans
rolex watches for sale
nike free flyknit 5.0
ugg boots
coach outlet online
yeezy boost 350 white
michael kors bags
air max 90 white
ralph lauren outlet
louis vuitton bags
converse sale
coach factory outlet
adidas shoes
nike free flyknit 3.0
burberry outlet
nike air force
cheap ray-ban sunglasses outlet
tory burch shoes
nike tn pas cher
chaussure louboutin
adidas nmd runner
louis vuitton handbags
skechers outlet
oakley sunglasses cheap
cheap jordan shoes
ray bans
adidas nmd black
reebok classic
adidas trainers
vans store
nike cortez white
pandora charms
air max 90
adidas shoes
fitflops shoes
timberland uk
pandora charms uk
armani exchange
burberry bags
under armour
louis vuitton outlet stores
oakley sunglasses wholesale
pandora jewelry outlet
cheap basketball shoes
ferragamo
ralph lauren
pandora rings
toms outlet
michael kors outlet online
prada sunglasses wholesale
cheap ray bans
www.coachfactory.com
cheap air jordans
michael kors handbags
valentino
michael kors outlet clearance
michael kors outlet
ugg boots
ralph lauren
ghd
mizuno running shoes
nike air force black
cheap jordans
nike free run flyknit
cheap ray bans
sac longchamp
kate spade outlet
cheap ray ban outlet
ray bans
true religion jeans
babyliss hair dryer
michael kors bags
true religion outlet
reebok outlet store
ray bans
nike trainers
polo outlet
fitflops
adidas superstars
true religion outlet store
kate spade uk
discount nike air max
ray ban sunglasses outlet
jordan pas cher
levis 511
nike huarache
omega speedmaster
christian louboutin uk
michael kors outlet store
tiffany jewelry outlet
polo ralph lauren men
adidas supercolor pink
rolex replica watches
ray ban outlet store online
cheap nike air max
coach outlet store online clearances
tory burch flats
hollister hoodies
nike cortez shoes
louis vuitton outlet online
hollister hoodies
pandora jewelry
louboutin outlet
coach factory outlet online
adidas pure boost black
designer handbags wholesale
yeezy boost 750
true religion
kate spade outlet online
tiffany uk
lebron james shoes 12
red bottoms outlet online
cheap jordan shoes
jordans
gucci borse
gucci handbags outlet
ray ban sunglasses sale
lacoste shoes
bottega veneta shoes
michale kors uk
ray ban sunglasses discount
louis vuitton uk
cheap ray ban sunglasses
longchamp outlet
micahel kors
adidas superstar white
air max
cheap nfl jerseys
burberry outlet
christian louboutin outlet
hollister clothing store
oakley sunglasses outlet
ralph lauren
nike blazer
michael kors canada
birkenstock sale
cheap ray bans
white converse
louboutin pas cher
jimmy choo
ed hardy uk
bottega veneta sale
north face outlet
nike air max 95
burberry sale
abercrombie and fitch outlet
hollister kids
louis vuitton purse
supra outlet
nike huarache black
nmd adidas
asics running shoes
lacoste polo shirts
jordan shoes
michael kors canada
abercrombie & fitch
coach outlet online
tiffany jewelry
burberry outlet canada
ray ban sunglass,ray ban sunglasses,ray ban outlet,cheap ray bans,cheap ray ban sunglasses,cheap ray bans,ray bans
ralph lauren outlet online
canada goose outlet
mlb jerseys wholesale
vans outlet store
birkenstock sale
coach purses on sale
ferragamo outlet
valentino bags
rolex submariner
mont blanc outlet
hollister co
nike air force
the north face outlet
armani outlet
tiffany and co outlet
michael kors handbgas
cheap oakleys
north face jackets
dior sunglasses 2016
coach outlet online
north face uk
kate spade bags
polo ralph lauren outlet
ray ban outlet online
adidas nmd uk
ghd hair dryer
jordan shoes
hollister uk
michael kors uk
buy red bottoms
nike roshe run
kate spade outlet
toms shoes
cheap oakleys
louis vuitton factory outlet
polo ralph lauren outlet online
puma outlet
true religion uk
chi flat iron
fitflops sale clearance
true religion jeans outlet
michael kors outlet canada
michael kors outlet
oakley sunglasses
instyler max
true religion jeans
fitflops
fitflops shoes
polo ralph lauren
pandora sale
michael kors outlet stores
hermes outlet
cheap oakley sunglasses
nhl jerseys wholesale
toms outlet
longchamp uk
timberland shoes
asics gel kayano
michael kors outlet
ed hardy
polo ralph lauren
versace sunglasses wholesale
louis vuitton borse
kate spade handbags
new balance shoes
versace sunglasses
birkenstock outlet
oakley sunglasses,oakley sunglass,cheap oakley sunglasses,oakley sunglasses cheap,oakley sunglasses outlet,oakley store,oakley outlet,oakley outlet store,oakley sunglasses sale,oakley sunglasses discount
michael kors bags
birkenstocks
nike air max 90
timberland boots for men
kobe bryant shoes
adidas shoes
birkenstock shoes
christian louboutin shoes
under armour outlet store
rolex daytona
michael kors outlet
abercrombie outlet
birkenstock uk
cartier
omega
polo ralph lauren
true religion sale
burberry outlet stores
nike shoes for cheap
nike store uk
sac longchamp pliage
nike force 1
ecco outlet
coach outlet online
louboutin shoes
canada goose jackets
nike free runs
reebok
converse outlet
coach outlet online
stephen curry basketball shoes
hollister kids
jimmy choo outlet store
nike air max 90
hermes belt
louboutin shoes
supra store
stan smith adidas
toms outlet
rolex watches uk
wholesale nike shoes
gucci outlet online
yeezy boost 350
nike free 5.0
cheap nfl jerseys
reebok shoes
coach outlet online
coach outlet store
tiffany and co jewelry
timberland shoes
ray ban outlet
timberland boots on sale
cartier love ring
white converse
louis vuitton purse
air max 90
ralph lauren pas cher
air jordan shoes
prada handbags
michael kors canada
holliste sale
adidas gazelle
nike flyknit racer
oakley sunglasses uk
yeezy boost 350 balck
lebron james shoes 2016
ralph lauren outlet
nike running shoes
kobe 11
nba jerseys wholesale
coach outlet store
michael kors handbags outlet
hollister clothing
louis vuitton pas cher
ralph lauren sale clearance
cheap oakley sunglasses outlet
"One of the most popular, but simple fifties dresses, is the petticoat. This was designed to be flattering to a lady's shape and also, to enhance the dress she was wearing over it. Petticoats made of silk and woollen materials were initially introduced for women to wear under the main dress, as they provided warmth and would enhance women's busts. The classic petticoat then became shorter and lacy petticoats became the fashion, as they delicately accentuated the dresses that were worn over them, such as the Ophelia dress.
Vintage style dresses UK are available in a wide variety of sizes from vintage clothing shops, textile fairs, auctions, flea markets, estate sales, antique markets, garage sales and collectable fairs. However, there is always the risk with buying genuine vintage clothing, that the sizes may not match current clothing sizes. But there are a number of special boutiques online, who specialise in designing and creating vintage clothing to order. They can take your specific measurements and produce an outfit that will be tailor made and fit you perfectly"
GDHDH
