Truma Combi 6 (gas only) no hot water
Jan 31, 2026
hi,
new to caravan forums, but been struggling to find any answers or thoughts regarding an issue I'm having.
I have a 2024 hobby (Import) which has truma combi 6 gas only source which seems to be having a dickie fit.
i can run blown hot air up to the desired temperature and the system nicely maintains this temperature. but when i try ask for hot water i only get a small amount and then nothing. ( presume small amount is due to water being heated as the heating is running.
if i switch off the heating and just set up for hot water, after a minute boiler kicks into life fires and then stops after a minute. (no hot water to tap) when hot tap running boiler will not fire as i would normally except.
i have no error messages showing up on truma cp plus panel.
Gas is fine, 12 volt electric are working (brand new 110ah AGM battery).
any help or useful suggestions would be gratefully received.
Jun 6, 2006
1,032
253
Presumably you have purged all the air out of the hot side of the water system?
What setting have you set for the water?
If you set the water to boost does the boiler respond?
Jan 31, 2026
hi,
All the purged from the system.
i have tried all settings for the water, Eco, Hot and boost.
boost will fire up the boiler after 1min aprx and run for aprx 1 min before shutting down.
on reading more i have discovered that this unit is not instant heat and will not fire on demand of hot water so that clears that side of query, but i should in theory still be able to heat 10.5L of hot water without the need of heating too.
Jun 6, 2006
1,032
253
Yes, not instant hot water, probably 40 + minutes to heat up the water when it’s not cold outside, longer when running heating as well.
