hi,
new to caravan forums, but been struggling to find any answers or thoughts regarding an issue I'm having.
I have a 2024 hobby (Import) which has truma combi 6 gas only source which seems to be having a dickie fit.
i can run blown hot air up to the desired temperature and the system nicely maintains this temperature. but when i try ask for hot water i only get a small amount and then nothing. ( presume small amount is due to water being heated as the heating is running.
if i switch off the heating and just set up for hot water, after a minute boiler kicks into life fires and then stops after a minute. (no hot water to tap) when hot tap running boiler will not fire as i would normally except.
i have no error messages showing up on truma cp plus panel.
Gas is fine, 12 volt electric are working (brand new 110ah AGM battery).
any help or useful suggestions would be gratefully received.
