colin-yorkshire said:
On the subject of LPG yes it is dangerious stuff but as a subject matter well within the cababilities of a COMPITANT diy'er spare parts and fitting are available everywhere. anyone who uses propane has to mess with it just to change the cylinder and never thinks about using a anti static straps, not to mention just about every gas BBQ or the self fit car gas conversions.
if you know what you are doing Lpg is no mystery and you don't need to be a quailfied gas engineer to do a proper job it is one of the things that elf and safety has gone mad with remember checking for leaks with a paintbrush and washing up liquid,
in the end it's down to the individual if you are compitant go ahead but if you are like the OP get someone to do it for you that knows what they are doing.
I'm sorry Colin, but I feel your post gives the wrong impression about who should or could work on LPG systems.
It boils down to who is competent, which then begs the question of how do you prove competency.
Competency is the ability to consistently demonstrate knowledge and skills about a subject to the satisfaction of a regulator.
In gas fitting, there is a lot more to getting the GasSafe ticket than just knowing how to make a joint. There are the safe working practices, the duty to test, and the knowledge to know how to specify the correct equipment appliance or installation, and the law - what you can touch and what you can't.
I'd venture that unless the DIY'er had been a gas fitter in the past, they would not be able to satisfactorily meet all those requirements, and thus could not be deemed competent.It is also highly unlikely they would have access to the necessary test equipment to be able to test to the regulations and certify work carried out.
I am strongly of the opinion that the current regulations that exempt individuals from being regulated and working on their own private touring and self propelled caravans is an Anathema. I have and will continue to lobby through my contacts for that exemption to be removed, so that only proven competent persons can work on any gas fuel system.
Compliance with good Health and safety measures is all too often mocked on this forum. It is sad to see so much lip service given to advice based on compliance.
Leave gas fitting to the professionals - your life and others may depend on it.
