Truma Saphir Compact Remote Control
Our Truma Saphir Compact Remote Control has 4 buttons (apart from on/off ) - mode, fan, + and - for temperature. The instructions for tuning it to the IR unit are for a Remote which has 14 buttons. Does anyone know how to use the 4 -button Remote to tune the IR unit please. TIA. Mike
Thanks very much for you quick reply. But if you look at your instructions they are for the 14 button type. (unless I'm losing it?!) Cheers. Mike
What are you calling 4 button type. Can we have a picture of your Remote if you slide the bottom of the Remote below the On Off down this exposes the other buttons which also exposes the Resend and also the Reset button
Yes but as I said below those buttons, open the front of the remote down and you have all the other buttons as shown behind it, as shown in the lower picture for setting. Click on Pictures I have taken with front of remote slid open halfway showing buttons behind second picture front of remote closed
Yes - thanks to Birdman. I'd crawled all over the remote but when I saw his two photos I slid the bottom part open - which was a little bit stiff and opened with a "click" the first time. I knew that the Air-Con was working because you can start in default mode by using a ball-point pen in a small hole in the IR unit.
Thanks for asking. Cheers. Mike
