Hi all, my truma ultra heat has stopped working on 2000w and 1000w. Just works on the 500w but not very good? Has anyone else had this problem if so did you find out what was causing it? Tia
Probably the relays that switch the power.
Get a qualified caravan engineer to sort it out as it more than likely needs the gas fire removing to get to it.
