Truma ultraheat pcb boad
Hi any tips on replacing the Truma ultraheat pcb board ? I managed to remove it which was very awkward being behind the fire and not wanting to remove the fire. I was wondering if anyone has any tips on replacement I think it’s going to be very fiddly and awkward trying to press down the little tabs to insert the wires and being in a confined space any tips would be appreciated thanks Daren.
Other than take the heater out it’s just a case of struggle
Got some heavy duty staples that I’ve straightened to use as pins to keep the wire holes open then slide the wire down the side of the pin then pull the pin out. Hopefully this works will find out tomorrow
I use a flat blade screwdriver to depress the tabs , but as others have said it is a case of struggling- I usually end up with a sore stomach! Also being an electronics engineer (retired) I tend to repair the pcb , it's usually the transformer thats popped , although sometimes it can be a faulty relay contact.
Thanks I’ve managed to replace the pcb and yes it was a struggle being in such a confined space but done it chuffed with myself everything now works as it should.
