- Jun 6, 2012
- 175
- 0
- 0
Hi all, recently while on site the truma ultraheat kept tripping the post, the hookup was 18 amp and the tank was full of water is there a fault with the heater?
shall i take it back to dealer as the van was purchased not long ago.Damian-Moderator said:Most likely a fault with the heating element.
thing is i cannot get the outer cover off with much tugging and pulling no luck.Damian-Moderator said:If it is still under some warranty,yes,
In the meantime, if you want hot water, use gas.
Remove the outer cover first or the gas will not work.
