F14nae said:If my log book says
Towable mass braked kg 1300
What can the caravan weigh? And would this weight include the things I put in?
Fiona x
Thingy said:You are correct, the maximum tow for your car braked is 1300kg. The kerbweight on the model you mentioned earlier is 1540 kg. The Maximum Technically Permissable Laden Mass or MTPLM as you will learn to call it, is advised, especially for a beginner to be no more than 85% of the cars kerbweight. In this case 85% is 1309kg, but my personal advice would be to look for something a little lighter as you are right on the cars limit.
This 85% figure, I must point out, is only advice, it isnt a rule as you may hear it called. It is however, good advice.
It is worth googling MIRO and MTPLM and read up on it. MIRO or mass in running order is something akin to a cars kerbweight for want of a better description. The difference between MIRO and MTPLM is the user payload, the stuff that you load into the caravan.
You also need to pay some attention to what the car can take on the towball. If I remember, the Zafira 1.7 was 60kg, but I may be wrong on that.
There will be others along shortly that will give you a much heavier version of this, which for a newbie can be a little confusing, but it is something that you really do need to learn.
This also may be of some use to you
https://www.caravanclub.co.uk/advice-and-training/training-courses/
F14nae said:You also need to pay some attention to what the car can take on the towball. If I remember, the Zafira 1.7 was 60kg, but I may be wrong on that.
Where would I find the towball weight? And what actually does this meansorry it’s all brand new :silly:
The nose load is created when more of the weight of the trailer sits infront of the trailers axle. Sometimes a trailer has too much nose load, in which case you need to redress the balance by placing some items behind the axle.
The "S" value should be stamped on the tow bar assembly for the vehicle., It will probably be in the hand book also.Thingy said:Your car will have a figure defined in the manual.
It is wrong to assume the S value for any vehicle . You should always check it for the specific vehicle involved. Different version of the same vehicle can have different S Values - Always check.Thingy said:Saloon cars are normally around 75kg, some less, some more. Some 4x4s have a much larger allowance
This is trueThingy said:If you have too little or too much noseweight, it can make for an unsettled ride at the very least.
Going for the maximum value is not always necessary. You only need enough nose load to keep the outfit under proper control. Going beyond what is necssary causes increased wear of the hitch, and the cars rear suspension. More is not always better.Thingy said:The holy grail is to have the noseweight as close to the cars limit as possible.
You do not need to purchase a noseload gauge. Non of the commercially available units account for the height of the cars tow ball when its loaded. You will get more consistemt results by using a set of bathroom scales raised up to match the height of the cars loaded hitch. The caravan step and few magazines under the scales is usually sufficint.Thingy said:Get a noseweight guage, they cost very little
Dustydog said:Hi Prof,
It would help if you kindly explained what S and D values are. I know as do some of the old lags on here but a new joiner , may just get more confused. Thanks
Exceeding the manufacturer's specified towload limit is not illegal. Only exceeding the plated limits (max. gross vehicle weight, max. gross train weight, max. axle loads) is illegal. The towload limit only has warranty and product liability implications.Raywood said:If the manufacturer states 1300 kg, then anything beyond that would be illegal, and if that excess weight caused or contributed to an accident it could affect your insurance cover.
is not incorrect.Your car will have a figure defined in the manual.
Thingy said:Aye aye, my watch has been dismantled again.
Agreed, but why not simply get it from the handbook rather than grot about on the floor. My statement
There was no suggestion that one should assume this figure, I was generally giving a guide, nothing more. Most cars do seem to have a noseweight figure of 75 kg, but you do have to be careful hence me stating that some can be lower. And it is true that most 4x4s have a considerably higher noseweight allowance.
Again, nowt wrong with this statement. It isnt rocket science to know that, all other factors being equal, and being within the cars accepted value, a slightly heavier noseweight is better than one that is too light. On a single axle caravan, a noseweight that is very light will often indicate poor loading.
And I suggested
Again nothing wrong with that idea or your method of stacking the bathroom scales on a pile of magazines to raise it to the towball height. Both methods are acceptable and used, and neither is fully accurate. Bathroom scales are usually fairly inaccurate and unless you are going to have the road surface levelled and calibrated, neither method will be 100% accurate. whichever method you choose will only be an indication.
The difference here prof between you and I is that I dont get bogged down with finite figures. Caravanning isnt an exact science, and many of your answers can make newbies think it is. I am not trying to be unkind here but in reality, its never going to be laboratory level, but more using all these items as sensible practice.
At the end of the day it all comes down to personal choice as to how you prepare for a journey, and the tug and caravan that you choose. And over time, everybody develops their own "best practice", but you will never ever get everything exact. And the kicker to this is that often, if you do get somewhere close, the actual tow experience will be somewhat less than optimal. It all comes down to learning your own particular outfit and how it feels on the road.
Lutz said:Exceeding the manufacturer's specified towload limit is not illegal. Only exceeding the plated limits (max. gross vehicle weight, max. gross train weight, max. axle loads) is illegal. The towload limit only has warranty and product liability implications.Raywood said:If the manufacturer states 1300 kg, then anything beyond that would be illegal, and if that excess weight caused or contributed to an accident it could affect your insurance cover.
The towing limit is what the manufacturer states the car can restart five times on a 12% hill and seems to have nothing to do with safe towing,
Thingy said:The towing limit is what the manufacturer states the car can restart five times on a 12% hill and seems to have nothing to do with safe towing,
I wholeheartedly agree with this. For instance my car has a maximum towing limit of 3500kg, which as we all know is a lot. My caravan has a MTPLM of 1735kg and believe me the car knows when its on the back. Accepting that a car trailer behaves totally different from a caravan, as does a horsebox etc, I feel it would be sheer lunacy to tow 3500kg especially at motorway speeds. Yes, across a field at very low speeds, but nothing more.
Raywood said:Lutz, I have said something similar before but been shot down. The towing limit is what the manufacturer states the car can restart five times on a 12% hill and seems to have nothing to do with safe towing, other than if you exceed it you might get stuck on a hill. I have pointed out on previous threads that a prosecution based on this would be difficult as it does not show that the outfit is unsafe.
I have been told in no uncertain terms though that exceeding it is illegal and if stopped at a checkpoint you would not be allowed to proceed unless the situation is corrected and could be prosecuted..
Lutz said:Raywood said:Lutz, I have said something similar before but been shot down. The towing limit is what the manufacturer states the car can restart five times on a 12% hill and seems to have nothing to do with safe towing, other than if you exceed it you might get stuck on a hill. I have pointed out on previous threads that a prosecution based on this would be difficult as it does not show that the outfit is unsafe.
Perhaps those that shot you down would be so kind as to reference the source of their information as I can find nothing to that effect.
EH52ARH said:I am with Raywood, I would not like to tow a trailer at the max load all the time, it is just too heavy.
