- Jul 15, 2008
- 3,888
- 1,064
- 20,935
What has puzzled me for a long time is why no manufacturer has used a turntable design for their larger range of caravans.
With 2 axles with 4 tyres carrying the weight and a wheel at each corner of the caravan, this would do away with most of the instability problems associated with the balanced trailer designs we have now.
Worrying about noseweight and small payloads would be a thing of the past.
Surely the caravan could have disc brakes, possibly electrically operated and controlled directly from the tow car.
Rod operated drum brakes must be a thing of the past.
This type of trailer is almost impossible to reverse using the tow vehicle.
However this is no longer a problem because a motor mover could be fitted to the turntable axle and all reversing could easily be carried out by means off this. The increased payload could accommodate larger 12-volt batteries for this purpose.
The front of the caravan would have to have a raised floor to allow the front axle to pivot to provide steering. This area could be a streamlined, windowless storage area extending to the full height of the caravan.
The back of the caravan could have a vista window and contain the lounge area.
The area in between could fit the bathroom bedrooms and kitchen as required.
They say everything goes full circle.... perhaps we should go for a 21st Century design of the original Gypsy caravan.
